Badger5EM Tuning
    Sep 2012
    6
    Audi A3 8L Concert Stereo Upgrade
    I am replacing my Audi Concert, rear amplified, with a Sony DSX-A40UI (Halfords | Sony DSX-A40UI Radio with iPod/iPhone, AUX & USB connectivity).
    I removed the Concert stereo and connected the car wiring up to a PC9-404 and an amplified ISO adaptor.
    There remains a single brown connector which was screwed into the back of the Concert. What is this and where should it go?
    There is a blue wire coming out of the amplified ISO adaptor. Where should this go?
    The aerial adaptor doesn't fit into the back of my new stereo, I must need another adaptor but other than that sounds comes out of the speakers and when I take the key out of the ignition the stereo turns off.
    However the stereo is not storing memory so I guess I am missing a permanent live connection? Surely there was one for the old Concert? What to do?
    Thanks for any help - this is another 10 minute job that is taking all day!
    Sep 2012
    6
    Well I solved the memory problem. It seems that my live and switched live connectors were the wrong way around.
    Apr 2007
    Wirral
    196
    Connect the blue wire to the remote antenna cable from the headunit.
    Sep 2012
    6
    Thanks Emmo. I thought about it overnight and came to the same conclusion.
  1. Concert stereo upgrade help needed!
    By DCW87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2013, 09:38
  2. Will an Audi TT 2004 Concert Stereo fit in an Audi TT X Reg?
    By thassall4295 in forum TT/TT-S/TT-RS Forum
    Last Post: 31st July 2013, 12:54
  3. Audi Concert Stereo Upgrade
    By LibreYLoco in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2013, 19:15
  4. Using Aux input to play music - Audi S3 facelift - Concert stereo?
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2011, 17:26
  5. Audi S3 1999 concert stereo upgrade to USB head unit
    By racelineuk in forum In-Car Entertainment
    Last Post: 11th January 2009, 15:43
