Volks AutosSky Insurance
    Dec 2013
    Lincolnshire
    6
    instrument cluster compatability, need some one wiyh a bit of part number knowlage
    Hi all, I'm new to the forum but not not with cars, anyway seasons greatings.
    I'm in a bit of a pickle at the moment, Iv got my self a project car that needs a bit of tlc. Basically my s3 is a non start and Iv figured the instrument cluster is at fault, it douse the normal run for a second and cuts out, not only this, the rev counter dose not work when cranking, there is no millage, time/date and the central display dose not light up. I'm after a replacement set of clocks but I'm unsure as to wether I will need the exact part number or if there are a couple that cross referance, recoding shouldn't be a problem, if so Il be going down the immo delete rout.
    My part number is 8L0 920 980L.
    Are there another set of clocks that are compatable as a replacement or will I require that exact part number?
    The car is a 2001 s3 facelift AMK
    Thanx in advance
    Dec 2013
    Lincolnshire
    6
    I gather that I will need the exact part number for a replacement, dose anybody know if the millage can be changed to mach what it was prior to clock replacement?
    Nov 2013
    Heath Hayes
    952
    You can get immo Pins and correct the mileage with a VAG-TACHO or VAG-COMMANDER Lead.
    Audi VW VAG K+CAN Commander 3.6 For VW Caddy VW Crossgolf | eBay
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    May 2012
    RETFORD, NOTTS
    1,753
    Personally wouldn't use either of those to change the milage.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Dec 2013
    Lincolnshire
    6
    Clocks were ordered lastknight, what other methods are there and what are the pros and cons regarding millage cha.nge. the cluste Iv baught has more than double the mileage of my car, but they ere cheap!
  1. Need some links to purchase a few parts :)
    By Mi11ar in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2013, 17:05
  2. Instrument cluster compatibility
    By PAULF in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2011, 02:16
  3. A4 1.8Turbo 2002 Instrument cluster wiring diagram Needed,
    By Ciaran in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2010, 22:28
  4. What hardware is needed to change the instrument cluster?
    By Gustaf in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2009, 19:53
