JMB RetrofitsAH Fabrications
Results 1 to 24 of 24
Like Tree3Likes
  • 1 Post By Nick101
  • 1 Post By badger5
  • 1 Post By Bad Sir Culation
Thread: Metal shavings in the oil strainer...... Should I be really worried??
    Nov 2011
    Leeds, UK
    287
    Well this morning I have taken the sump off to change the oil strainer because I didn't like the way the car sounded when started up. It sounded very much like a diesel and I remember this being a symptom of a blocked oil pickup pipe strainer.
    So, having got the sump off despite the ball end on my 5mm long allen key snapping off in the head of one of the bolts, I took the strainer off to find this:
    To say I am worried about this would be an understatement!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    Unless you wana tear down you engine there isn't alot you can do.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Has the head been skimmed at some point in its life?
    It looks like swaf left over that was stuck in the head after skimming but not fully blown out
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    when turning my car over, it sounds like a diesel starting. but as soon as it fires, its sounds like a petrol.
    Its just similar sound to turning my TDI A3 Over and my S3.
    Is this normal? Eg the starter motor sound….
    Nov 2011
    Leeds, UK
    287
    No idea guys. It was a £1500 S3 with bugger all history, so anything is possible!
    Nov 2011
    Leeds, UK
    287
    Found a couple of reddish ceramic or plastic bits too. There's so much metal jammed into the strainer that I'm very glad I bought a replacement.
    RIP S3dave
    May 2004
    nr Glos
    7,195
    looks fecked to me Whats the coily thing? helicoil sump plug?
    looks nasty...
    not normal to sound like a diesel on startup no... that would be bearings and oil pressured related morwe than likely
    rebuild time to know its right
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    It does look like machining swarf, and a stripped sump bolt thread. Red stuff I would guess, cam chain tensioner guide. Wild guess tho
    Nov 2011
    Leeds, UK
    287
    Does look like machining swarf. No evidence of any metal in the oil filter etc. Fingers crossed!
    Have now got the sump back on, and just hoping the sealant is correct. Will find out in the morning when I fill it and run it.....
    Nov 2011
    Leeds, UK
    287
    looks nasty...
    We'll see how it sounds when I refill it. Hopefully it's OK. There's just no way I could justify a rebuild on a £1500 car.
    Boost fiend
    Dec 2008
    Swansea
    215
    Red bits could be broken bits of oil dipstick tube, common for them to break and go down the pipe.
    s3dave likes this.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Doesn't look ideal but if it was a cheap buy why not just tidy it up and just run it until you hit a problem? If you were lucky, the strainer did its job and caught most of it.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I always use a magnetic drain plug, it could save your engine being starved of oil...
    Like said its done its job, and you ave cleaned it fingers crossed for you all is well..
    RIP S3dave
    May 2004
    nr Glos
    7,195
    every ecs magnetic drain plug I have seen on every 1.8t thats been thru the workshop has damaged the sump threads
    hopefully there's another make which does'nt cause as much carnage
    Sam_ likes this.
    www.badger5.biz
    bill@badger5.co.uk
    Jan 2012
    Kilmarnock, Scotland
    343
    I use QPS mag plugs. They're peanuts to buy and I've never had any issues. I don't tend to over tighten things though and I'm generally careful. I can't really see how the plug could cause damage to threads on its own
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Its the alloy ones that are the issue... kinda cold welds like stainless can
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    If anyone knows of a decent magnetic plug let me know. The last "decent" one I bought cost me a frigging sump .
    Nov 2011
    Leeds, UK
    287
    Well I got it all filled back up today and it's all running great. Well, I think I've managed to create an air leak somewhere as it's struggling to idle a bit (I know there's a jubilee clip I damaged and it isn't fully tight, so will swap it out), and there may be a very slight oil leak from the sump, but as far as the metal bits, rough sound on start up etc. it's all gone.
    Very pleased overall.
    bigray likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,195
    cool & lucky too
    hope it continues
    www.badger5.biz
    bill@badger5.co.uk
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Yep - mine came with an ECS sump plug (fitted by a local specialist) and after 2 oil changes, the threads came out with it.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Quote Originally Posted by Bad Sir Culation View Post
    Nice one. A bit of TLC and they seem to last fairly well. I've done nearly 40,000km and not had any major issues. Touch wood.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by Sam_ View Post
    This is worrying :-/
    I've had two oil changes with my ECS sump plug so far, so hope I don't run into this issue with the next one, although my sump threads never been great so I think a Forge baffled one for the new year is due for an order - and see how the ECS plugs in that being brand new.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    looking at alternatives to the ECS one:
    M14 x 1 5 Magnetic Oil Sump Drain Plug
    Which is expensive but they claim its the best.
    But my fav for price and looks:
    Magnetic Sump Plug M14 x 1.5. Oil Drain. FORD MAZDA VOLVO VW AUDI SKODA SEAT | eBay
    Just thinking that a magnet that protrudes is better than one that is flush, hmmmm....
    Nov 2011
    Leeds, UK
    287
    I have always run magnetic plugs in the past and will probably do so again the next time I change the oil. I plan to change this in about 3k just to be sure everything is as it should be.
  1. Is it worth me replacing the oil pump strainer?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 20:30
  2. 2 Q's: Changing the Oil and Camblet
    By fraz in forum TT/TT-S/TT-RS Forum
    Last Post: 7th January 2006, 14:58
  3. Is there a valve in the oil filter and cooler?
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 12:44
  4. S3 AMK Engine - Anyone know the oil filter part number ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2005, 17:20
  5. Replies: 12
    Last Post: 19th April 2005, 13:27
