Chris NottAH Fabrications
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By 16Klappe
Thread: soda blasting - anyone tried it?
    Oct 2013
    in the middle
    109
    as above, i have a used 02M gearbox to refurb, first step is to clean the outside.i have ben looking at you tube and it seems pretty easy to make a very basic blasting nozzle and using soda as the blast media looks to be quite usefuli have a decent sized compressor,should be ok for a small blow gun based kit just wondering if anyone had experiance of using soda on greasy/oliy engine partsthanks
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    I once put a mento in a soda stream bottle then put it in the machine.
    It blew up.
    Lavis89 and @udi A3 like this.
    I quite often say I'm going to do things.
    Then never do them.
    Nov 2013
    Heath Hayes
    951
    Just get some of this http://www.autoexpress.co.uk/accesso...ma-hyper-clean
    Have used it to clean off a gearbox I was swapping into my Passat. Brush in leave for a minute and rinse off. Repeat with really thick stuff.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Quote Originally Posted by 16Klappe View Post
    It blew up.
    *like*
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Oct 2013
    in the middle
    109
    Quote Originally Posted by desertstorm View Post
    Just get some of this http://www.autoexpress.co.uk/accesso...ma-hyper-cleanHave used it to clean off a gearbox I was swapping into my Passat. Brush in leave for a minute and rinse off. Repeat with really thick stuff.Karl.
    could do that, i have a 5 gall jug of industrial cleaner, just wanted to play with a grit blaster edit: like this http://www.youtube.com/watch?v=aQrU06w7LHY
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    My cam cover was soda blasted, was pretty good!
    Lewis583's Avatar
    Mar 2010
    870
    Me and my dad made a small enclosure for media blasting. Worked pretty well, did require a good sized diesel compressor though which when running full throttle (to keep up with air demand) makes a **** load of noise. So I hope your neighbours are friendly.
    Was able to do small things easy enough (Brake disc backing plates/axle brackets/fuel tanks straps etc) and while it could take a wheel it proved a pain in the ass to get round it so they were sent away to be blasted.
    There are some pics in my build thread if you want to get an idea.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
