JMB RetrofitsAH Fabrications
Results 1 to 19 of 19
    matt blowen's Avatar
    Jul 2013
    staffordshire
    140
    Add matt blowen on Facebook
    Coolant air lock
    Hi there is there a special way to bleed air out of the cooling system? Its a 1.8t agu, heaters blow cold air and i can hear bubbling in the pipes?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    I've never had any trouble bleeding a 1.8T, but some folk seem to have a real nightmare with them.
    If you glug it full of coolant, start it and drive off, you'll almost certainly have issues, as the engines nowhere near full.
    My process is simply dont rush it. Fill it with coolant and leave the cap off. Walk away and leave it for a while. Dont start it, drive it or do anything else. Ususally theres other things that need done on the car so go do those. Check the level periodically and you'll notice its dropped. Refill and leave it again. Repeat a number of times over say an hour or two, giving the big rad pipes a squeeze now and then and that usually does it. The first few times you'll find the tank completely empties itself over a period of time, but with each subsequent fill this will happen less and less, and eventually the level will stay where it is.
    When i do the above, once i'm ready to drive i just fit the cap and set off, round the block a couple of times until it comes up to 90 and the stat opens, then recheck the levels, but most of the time they dont move.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    I always get air locks. Maybe I'm doing I wrong.
    To solve the issue. I fill the header tank till it stops draining, then remove the upper radiator hose fitting and pour some coolant into the radiator.
    Jul 2013
    staffordshire
    140
    Right ive tried everythink, still getting no flow round the matrix? Ive took the small return hose off the top of the header and all that comes out is steam. Any ideas?
    Jul 2013
    staffordshire
    140
    Heaters worked before i drained the coolant
    RIP S3dave
    May 2004
    nr Glos
    7,177
    manually try and fill the problem pipes as they are the highest ones.
    some fill fine, when filled slowly, some are a pig.
    have heater on full hot when starting so valves open etc... presuming your valve works and no faultcodes etc??
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    After my accedent I got one of these
    Coolant Filling Kit - YouTube
    Not cheap but I won't burn my arm again
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Jul 2013
    staffordshire
    140
    Oh god i remember, how is your arm now? Ive spent all day trying to bleed the car still, ive tried everythink apart from using garden hose because i aint got one
    Jun 2009
    Leeds
    3,470
    healing well.
    FOR SALE
    dusty's Avatar
    Nov 2010
    nw england
    144
    Hi, you could try getting a 2 litre pop bottle cut the bottom off it then fit a rubber o ring onto the kneck/bottle top end, then use the bottle as a funnel in the coolant resevoir, remove a hose from the engine and overfill with coolant so you have coolant in the funnel, so your coolant in the funnel is well above the position of the engine, this should push any air locks you have out of the disconnected hose, not tried it on the s3 but it used to work on another car that I used to own
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    Jul 2013
    staffordshire
    140
    Havent tried this, should i remove the small return hose to vent the air?
    dusty's Avatar
    Nov 2010
    nw england
    144
    Yea you will need to remove a hose to allow the air to escape
    Nov 2013
    108
    I can't recommend it but letting the car cool for 30min and then pulling out the coolant sensor for a few seconds worked for me, there was air in the system that wouldn't budge. Coolant temp wouldn't go above 85.
    Sits at 90 now rock solid after my ghetto fix.
    Just make sure the pipes are Luke warm not hot!
    Jul 2013
    staffordshire
    140
    Ill try that in a min thanks, im starting to wonder if my water pump is shot
    Nov 2013
    108
    Undo the coolant cap first. Coolant does pump out of its own accord when you take the sensor outif its warm. I just made sure I did it in the street and not on the driveway, keep her indoors happy...... Then just fill up the coolant reservoir if it goes to low
    Jul 2013
    staffordshire
    140
    Ok so if i let it idle for a bit then turn it off, open cap then pop off the cts and just keep topping up the tank when it gets low?
    Jul 2013
    staffordshire
    140
    Does it help if the car is level?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    what temp does the car run at ?
    if your not getting any return normally a sign of a failing water pump.
    try having it done with a vacuum bleeder.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Jul 2013
    staffordshire
    140
    Its gets to 90 quicker than before i fixed the water leak, but goes past 90 atfer 15 mins of idle and when it reaches 100 i turn the off
