Sky InsuranceEM Tuning
Results 1 to 10 of 10
    chaz20vt's Avatar
    Aug 2012
    425
    APY bearings same as AYP
    Hi im planning on rebuilding my engine in the new year i have a 1999 Audi S3 APY, I want to replace the following parts......
    Rods (rifle drilled)
    Rod Bearings
    PistonRings
    Cambelt kit & Water pump
    Head Gasket kit
    Head looked at..
    Head Bolts
    Oil pump
    Oil pickup
    Obvious gaskets (that are needed)
    BBT Hybrid k04
    New Exhaust Mani (hopefully Badger one)
    550cc Injectors
    Relentless 3inch DP
    WMI (of some sort)
    Now my main question is I have a AYP bottom end which has had new bearings and piston rings fitted, It was started and run for around 2 miles.
    Would the bearings and Piston rings out of the AYP engine fit my current APY engine as there basically brand new.
    Or am i being stupid and should just buy new again????
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    same units, but depends on wear on your new block. Why not install the already done AYP bock ?
    chaz20vt's Avatar
    Aug 2012
    425
    As it has a oil leak on the craft seal...
    I was also hoping to leave my bottom end in the car....
    chaz20vt's Avatar
    Aug 2012
    425
    Any one able to give me some advice on this?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    I'd fit new ones mate. Pistons might be ok just check there's no damage. But bearings should always be new and never transferred IMO. The wear may be different and you never know, could lead to disaster!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Change piston rings too.
    chaz20vt's Avatar
    Aug 2012
    425
    So the rings and bearings from the AYP which have only had around 15-20 mins of running time (so i should tink not run in)are no good to use again????
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    I wouldn't say that they are not good, you can use them again, but new ones would always be better.
    limbo118118's Avatar
    LORD
    Oct 2009
    Wrexham.. North Wales
    355
    Add limbo118118 on Facebook
    for what its worth id just buy brand new again, saves anything going wrong and having to strip it all down again..
    chaz20vt's Avatar
    Aug 2012
    425
    Ok thanks for that. ..
  1. APY same internals as an AYP?
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2012, 17:32
  2. S3 Front Wheel Bearings same as A3 quattro?
    By Colly in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2012, 16:55
  3. Does the a3 (8p) and golf mk5 have same wheel bearing?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2011, 19:43
  4. Any Other Bare Blocks The Same As APY
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2010, 19:35
  5. ARY and APY are the head the same?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 18:48
