JMB RetrofitsEM Tuning
Results 1 to 11 of 11
Thread: Badger 5 V2 TIP
    millsy75's Avatar
    Dec 2012
    196
    Badger 5 V2 TIP
    Good evening fellow petrol heads. I had my badger V2 tip fitted today to replace my forge item (very nice). I was booked in to have a forge catch can fitted at the same time. The catch can couldn't be fitted due to the design for the location and the size of the badger tip.
    I would like to do the catch can mod but now need an alternative and possibly also an alternative fixing location. Can you help? (complete novice)
    Also would anything need to be adjusted on my map after fitting the new TIP? It's just a Revo stage 2, not custom.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Check out my latest post mate. I've just fitted the tip and occ last night
    BAM S3 full rebuild for Hybrid or BT
    millsy75's Avatar
    Dec 2012
    196
    Great thanks pal. Was the 42 draft design bought as a kit?
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Didn't think forge do a OCC for the S3?
    i know they do it for the TT.
    I made the kit myself
    millsy75's Avatar
    Dec 2012
    196
    Yeah forge do a full kit mate. Check eBay number - 271178934713
    millsy75's Avatar
    Dec 2012
    196
    Ah yeah it does say TT but Awesome had got one in for me anyhow. I just presumed it would be the same
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Thought so, this is specific to the TT, or what forge was telling me as there's no room to fit that in the S3 where they mount it in the TT. That's why I bought the 42 version and custom piped it
    millsy75's Avatar
    Dec 2012
    196
    OK thanks, that looks like what i'll have to do. The kit was ideal for me as I don't know what is required. Thanks for the info.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Plus that looks like it just plumps into the OEM PCV system where as I removed all of that and used a new "hockey puck" and blanked off the intake mani port and ran direct from the crank vent and joined it into the rocker vent then into the catch can and from can back into tip.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    You need a 19mm in/out can with strainer, 2mtrs of oil/fuel proof hose, 2 x 19mm elbow connectors, 1 X 19mm 3 way connector (depending on your hose routing and whether you run back to tip or vent to atmosphere), new oem "hockey puck" and new oem crank case vent plastic elbow. Oh and about 14 jubilee clips, again depending on your pipe routing.
    millsy75's Avatar
    Dec 2012
    196
    Thank you, i'll look into getting the parts sourced
  1. Badger 5 TIP
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2012, 11:40
  2. Badger-5 tip and maf fitted....
    By BENJAMIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 15:44
  3. Replies: 8
    Last Post: 17th July 2011, 18:08
  4. Westle and S3baby's late night mechanics. (Badger 5 TIP)
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2011, 18:51
  5. Who's fitted a badger 5 tip???
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2011, 16:15
