Page 1 of 5 12345 LastLast
Results 1 to 40 of 167
Like Tree89Likes
Thread: g60leigh build thread. it's gonna get messy
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    I have been a member of the forum for a while now, but spent most of my time reading others builds and asking for help and info, I have added a few posts on my projects in the past but nothing to major
    I have been meaning to create a build thread for a little while but my personal build has been a little slow.
    Until now, as it seems to be taking off and things are starting to get MESSY!.
    I will throw together the bits and pieces of my build in here in the hope it is of some help or inspiration to others. It will most likely not be in true chronological order as my memory for dates is appalling.
    I started off with no intention to heavily modify as I loved the S3 in standard form. That did not last too long though.
    Rather than go through the order in which I have added things, here is a list of the spec changes to my car now:
    ENGINE:
    Porsche Alloy Oil Filler Cap & Porsche Alloy Coolant Cap (From ScottB5 Group buy)
    Forge FMDV008 Recirculation Dump Valve
    Revo Stage 2 ECU Map
    Badger 5 V2 TIP with J&R Cone filter and Heat Shield
    TFSI Coil pack upgrade with NGK Iridium Spark Plugs
    Evap removal
    Miltek Cat back stainless steel exhaust
    AH Fabrications V1 front mount intercooler
    Phenolic inlet manifold gasket
    Relentless V2 tubular steel manifold
    Relentless V3 3” Down pipe and 200 cell Sports catalytic converter
    Oil catch can and PCV removal (soon to be replaced with a new one of my own design)
    Titanium manifold heat shield
    Carbon fibre engine cover
    AEM 30-3000 Progressive WMI
    CG Motorsports 5 paddle clutch
    LUK DMF flywheel.
    CHASSIS:
    17" Ronal Avus Alloy wheels
    Neuspeed Front Anti Roll Bar (Poly bushed)
    R32 Rear Anti Roll Bar (Poly bushed)
    Powerflex Poly Dog bone Bushes
    XYZ Coilovers
    Poly bushed Rear Trailing Arms
    Compbrake adjustable Tie Bars
    LCR Brembo’s with B5 330mm 2 Piece Rotors
    ATE Superblue Racing brake fluid
    B&M Shifters short shift
    INTERIOR:
    TT Pedal Set
    S3Dave stainless foot rest
    Ambient Lighting Mod
    LED Interior light upgrade
    Retrofit RNS-D Double Din Satellite Navigation (With Xcarlink iPod connection)
    AEM boost gauge in custom vent pod
    EXTERIOR:
    Audi TT Fan Style Washer Jets
    VW Golf R32 Front Wiper Arms & Aero Blades
    VW Polo 6N Rear Wiper Arm & Aero Blade
    VW Yeti Stubby Aerial
    German pressed plates with Audi Sport surround
    Black Plasti Dip door blades and rear bumper trim.
    On the incoming list:
    Performance parameter display – displays gauge info on the OEM DIS – Supreme Technology & Engineering I will do a full write up on this when completed
    BBS RC041 split rims
    Custom oil catch can
    Comfort (1 touch 3 blink) indicator mod
    8P S3 chrome trim modded headlight switch
    Engine rebuild with IE rifle drilled rods, Bosch 550 injectors Stage 4 Hybrid turbo and custom map :D
    Some of my other threads:
    Fan Washer jets and aero blades
    Fan Style Washer Jet Upgrade / Aero Wiper Blades
    Gauge pod build
    A pillar gauge pod build thread.
    B&M Short Sifter
    Short shifter - different option.
    WMI
    WMI Help needed. Lots of it please!
    RNS Retro fit Sticky
    Double Din Conversion / RNS-D Retro Fit
    kwistof, Sandra and Jay A3 like this.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Looking forward to reading more on this. x
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    This is the turbo I've got:
    MD421 - Stage 4 Hybrid turbo comprises:
    High Flow K06 Billet Aluminium Lightweight Compressor Wheel
    Re-profiled compressor housing
    Turbo Dynamics designed uprated 360 degree thrust kit
    K04 Large trim turbine wheel with lightening modifications for quicker response
    Re-profiled turbine housing to suit new turbine wheel
    Turbocharger fully blueprinted to motorsport standards
    Max recommended boost: 24-26 PSI
    Estimated Power Output: 340-360 bhp with correct supporting modifications
    Its second hand but only got a few miles on it.
    Seems to be in excellent order but getting it checked prior to fitting.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    My new design oil catch can.
    I have fag packet cad designed this. With the intention of mounting it on the side of the battery bracket.
    Pics of mounting to follow once Royal Mail get it to me.
    s3dave and StaceyS3 like this.
    2001 S3 (AMK)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    That's a fairly large catch can
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by Scullies View Post
    Bigger is better ? Haha
    2001 S3 (AMK)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    Quote Originally Posted by g60leigh View Post
    that only applies to turbos, and certain parts of the human body
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Anymore Info of the headlight switch?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    ^^ In house magpie is at it....lol ^^
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    I think he's wondering how he's getting on fitting the chrome nob to his 8L switch as he attempted it before. Dani, I'll let you know when I got it.
    g60leigh likes this.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Looking forward to some more updates.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    As Scott says the progress of the 8P headlight switch is in his hands.
    Received the oil tank today. My fag packet cad design is slightly off so will take a little more tweaking than I had hoped but still confident that it will work and be a neat finish utilising otherwise dead space.
    2001 S3 (AMK)
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Nothing wrong with that, here's mine
    g60leigh, ScottD3 and bigray like this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    lorryz's Avatar
    Apr 2012
    Brisbane, Australia
    114
    \Pretty interested to see how this plays out
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Shut up dave haha. Keep me updated scott.
    s3dave and ScottD3 like this.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Update on the performance parameter display.
    😤 not good unfortunately. I've been working closely with the developers of this and even had a replacement box through but not making any progress. Seems that for reasons unknown this is not compatible with the A3/S3 DIS
    I'm not entirely sure what differs between ours and the A4 or TT ones but cannot make it work. 😭
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    To get over the disappointment of the PDD. I have tracked down a purchased one of these bad boys.
    Let the fun continue.
    Westy and superkarl like this.
    2001 S3 (AMK)
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    I'm jealous.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Been on the hunt for a long while. Ended up finding two for sale this week.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Scott's progress so far with the 8P headlight switch
    2001 S3 (AMK)
    S3 Paul's Avatar
    Oct 2006
    2,764
    Just reading you spec list is making me think reading this thread may prove expensive !
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,764
    So he has broke it?
    Im great at that part of the job... it the next stage that usualy involves duck tape and super glue
    Noggy Blue 2001 S3
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Go Scott go!
    Thank you mate. Pics of it installed when I get it back.
    bigray likes this.
    2001 S3 (AMK)
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    You want it back?<br />
    <br />
    Paul, Broke it.
    Cheeky.
    Westy likes this.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by ScottB5 View Post
    You want it back?
    Paul, Broke it. Cheeky.
    Yes please mate. I've messaged you. Its a pain in ass not been able to drive at night haha.
    2001 S3 (AMK)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    Go Scott go!
    I don't see a like button anymore, so just wanted to notify you that I like this
  28. #27
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    wheres the other one for sale ?? haha I've been after one for a while too!
  29. #28
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by aterro View Post
    PM me I will pass on a contact no
    2001 S3 (AMK)
  30. #29
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Haldex controller arrived this morning. Along with a few other bits. Wish I was in a fit state to do anything on the car at minute 😭
    2001 S3 (AMK)
  31. #30
    bigray's Avatar
    Oct 2013
    leeds
    147
    great build so far bud. and would love a haldex controller i need 1 for my golf,
    Quote Originally Posted by Andrew@A.L.D View Post
    and andrew any details on that battery like how much and were from please
  32. #31
    Jun 2009
    Leeds
    3,472
    Quote Originally Posted by bigray View Post
    I hope to be selling my Blue controller in the new year
    Its one from ebay ETX20L-BS YTX20L-BS 12V 18Ah AGM Motorcycle Battery
    FOR SALE
  33. #32
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    You pipe up with that AFTER I get one lol.
    Shout at me when your selling. I've a few people asking me about one so can pass info on.
    I've also picked up the bluetooth attachment for my xcarlink and a y-splitter for the obd portabd have a bluetooth obd dongle on order to install hidden away in the dash.
    2001 S3 (AMK)
  34. #33
    bigray's Avatar
    Oct 2013
    leeds
    147
    cheers dude, also be possible when you put it up forsale to drop me a pm. and out of interest you know if this would with after market management ?
    sorry for the the hijack g60leigh
  35. #34
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    My new haldex controller
    And a little extra spice to add to the build while the engine is spilt.
    Westy, StaceyS3 and Scullies like this.
    2001 S3 (AMK)
  36. #35
    Westy's Avatar
    Dec 2008
    17,283
    It annoys me so much tht these little blue boxes cost so much still!
    Good work so far Leigh
    S3 Build Thread
  37. #36
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by Westy View Post
    I agree that they seem to be so elusive and pricey. Only heard good things so I'm hoping its worth it.
    Would of thought these days a tuner could have a look at one and write their own equivalent code to make an alternative version.
    2001 S3 (AMK)
  38. #37
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Looking good Leigh..power user...
  39. #38
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Bit of a quick change in plans and it soon spirals outta control.
    2001 S3 (AMK)
  40. #39
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Today's delivery so far.
    Ready for rods install.
    2001 S3 (AMK)
  41. #40
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quick job for today.
    I'm pretty limited to what I can do at the minute after my spine surgery.
    Grabbed this after looking for a decent car hands free kit
    Was looking at parrot kits etc but was this one was pointed out to me by Scott.
    If you have an xcarlink, get one!
    Literally plugs into the xcarlink box. Plug in mic and pair it up to phone. Job done and as a bonus can bluetooth music from phone too.
    2001 S3 (AMK)
  1. Regal VF RSS S3 Build Thread..
    By jonnyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:04
  2. 2.0+l 20v stroker build thread (GT2871)
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2010, 09:13
  3. A3 Quattro build thread
    By mat20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2009, 20:03
  4. A3_Turbo's Build Thread
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2009, 15:05
  5. Gonna get new wheels.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st September 2005, 14:28
