g60leigh build thread. it's gonna get messy
g60leigh
Stockton on Tees
I have been a member of the forum for a while now, but spent most of my time reading others builds and asking for help and info, I have added a few posts on my projects in the past but nothing to major
I have been meaning to create a build thread for a little while but my personal build has been a little slow.
Until now, as it seems to be taking off and things are starting to get MESSY!.
I will throw together the bits and pieces of my build in here in the hope it is of some help or inspiration to others. It will most likely not be in true chronological order as my memory for dates is appalling.
I started off with no intention to heavily modify as I loved the S3 in standard form. That did not last too long though.
Rather than go through the order in which I have added things, here is a list of the spec changes to my car now:
ENGINE:
Porsche Alloy Oil Filler Cap & Porsche Alloy Coolant Cap (From ScottB5 Group buy)
Forge FMDV008 Recirculation Dump Valve
Revo Stage 2 ECU Map
Badger 5 V2 TIP with J&R Cone filter and Heat Shield
TFSI Coil pack upgrade with NGK Iridium Spark Plugs
Evap removal
Miltek Cat back stainless steel exhaust
AH Fabrications V1 front mount intercooler
Phenolic inlet manifold gasket
Relentless V2 tubular steel manifold
Relentless V3 3” Down pipe and 200 cell Sports catalytic converter
Oil catch can and PCV removal (soon to be replaced with a new one of my own design)
Titanium manifold heat shield
Carbon fibre engine cover
AEM 30-3000 Progressive WMI
CG Motorsports 5 paddle clutch
LUK DMF flywheel.
CHASSIS:
17" Ronal Avus Alloy wheels
Neuspeed Front Anti Roll Bar (Poly bushed)
R32 Rear Anti Roll Bar (Poly bushed)
Powerflex Poly Dog bone Bushes
XYZ Coilovers
Poly bushed Rear Trailing Arms
Compbrake adjustable Tie Bars
LCR Brembo’s with B5 330mm 2 Piece Rotors
ATE Superblue Racing brake fluid
B&M Shifters short shift
INTERIOR:
TT Pedal Set
S3Dave stainless foot rest
Ambient Lighting Mod
LED Interior light upgrade
Retrofit RNS-D Double Din Satellite Navigation (With Xcarlink iPod connection)
AEM boost gauge in custom vent pod
EXTERIOR:
Audi TT Fan Style Washer Jets
VW Golf R32 Front Wiper Arms & Aero Blades
VW Polo 6N Rear Wiper Arm & Aero Blade
VW Yeti Stubby Aerial
German pressed plates with Audi Sport surround
Black Plasti Dip door blades and rear bumper trim.
On the incoming list:
Performance parameter display – displays gauge info on the OEM DIS – Supreme Technology & Engineering I will do a full write up on this when completed
BBS RC041 split rims
Custom oil catch can
Comfort (1 touch 3 blink) indicator mod
8P S3 chrome trim modded headlight switch
Engine rebuild with IE rifle drilled rods, Bosch 550 injectors Stage 4 Hybrid turbo and custom map :D
Some of my other threads:
Fan Washer jets and aero blades
http://www.audi-sport.net/vb/a3-s3-...yle-washer-jet-upgrade-aero-wiper-blades.html
Gauge pod build
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/163922-pillar-gauge-pod-build-thread.html
B&M Short Sifter
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/172614-short-shifter-different-option.html
WMI
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/181839-wmi-help-needed-lots-please.html
RNS Retro fit Sticky
http://www.audi-sport.net/vb/a3-s3-...70-double-din-conversion-rns-d-retro-fit.html
Reactions: kwistof, Jay A3 and Sandra
Looking forward to reading more on this. :) x
This is the turbo I've got:
MD421 - Stage 4 Hybrid turbo comprises:
High Flow K06 Billet Aluminium Lightweight Compressor Wheel
Re-profiled compressor housing
Turbo Dynamics designed uprated 360 degree thrust kit
K04 Large trim turbine wheel with lightening modifications for quicker response
Re-profiled turbine housing to suit new turbine wheel
Turbocharger fully blueprinted to motorsport standards
Max recommended boost: 24-26 PSI
Estimated Power Output: 340-360 bhp with correct supporting modifications
Its second hand but only got a few miles on it.
Seems to be in excellent order but getting it checked prior to fitting.
My new design oil catch can.
I have fag packet cad designed this. With the intention of mounting it on the side of the battery bracket.
Pics of mounting to follow once Royal Mail get it to me.
Reactions: StaceyS3 and s3dave
As Scott says the progress of the 8P headlight switch is in his hands.
Received the oil tank today. My fag packet cad design is slightly off so will take a little more tweaking than I had hoped but still confident that it will work and be a neat finish utilising otherwise dead space.
That's a fairly large catch can :)
Nothing wrong with that, here's mine
Reactions: bigray, ScottD3 and g60leigh
Shut up dave haha. Keep me updated scott.
Reactions: ScottD3 and s3dave
Update on the performance parameter display.
😤 not good unfortunately. I've been working closely with the developers of this and even had a replacement box through but not making any progress. Seems that for reasons unknown this is not compatible with the A3/S3 DIS
I'm not entirely sure what differs between ours and the A4 or TT ones but cannot make it work. 😭
To get over the disappointment of the PDD. I have tracked down a purchased one of these bad boys.
Let the fun continue.
Reactions: superkarl and Westy
Just reading you spec list is making me think reading this thread may prove expensive !
Scott's progress so far with the 8P headlight switch
So he has broke it?
Im great at that part of the job... it the next stage that usualy involves duck tape and super glue
Haldex controller arrived this morning. Along with a few other bits. Wish I was in a fit state to do anything on the car at minute 😭
great build so far bud. and would love a haldex controller i need 1 for my golf,
and andrew any details on that battery like how much and were from please
I hope to be selling my Blue controller in the new year
Its one from ebay ETX20L-BS YTX20L-BS 12V 18Ah AGM Motorcycle Battery
You pipe up with that AFTER I get one lol.
Shout at me when your selling. I've a few people asking me about one so can pass info on.
I've also picked up the bluetooth attachment for my xcarlink and a y-splitter for the obd portabd have a bluetooth obd dongle on order to install hidden away in the dash.
cheers dude, also be possible when you put it up forsale to drop me a pm. and out of interest you know if this would with after market management ?
sorry for the the hijack g60leigh
My new haldex controller
And a little extra spice to add to the build while the engine is spilt.
Reactions: StaceyS3, Westy and Scullies
It annoys me so much tht these little blue boxes cost so much still!
Good work so far Leigh :thumbsup:
I agree that they seem to be so elusive and pricey. Only heard good things so I'm hoping its worth it.
Would of thought these days a tuner could have a look at one and write their own equivalent code to make an alternative version.
Quick job for today.
I'm pretty limited to what I can do at the minute after my spine surgery.
Grabbed this after looking for a decent car hands free kit
Was looking at parrot kits etc but was this one was pointed out to me by Scott.
If you have an xcarlink, get one!
Literally plugs into the xcarlink box. Plug in mic and pair it up to phone. Job done and as a bonus can bluetooth music from phone too.
