JMB RetrofitsSky Insurance
    Freeman_1986's Avatar
    May 2013
    Forest Of Dean
    S3 running lean...
    As title. The garage told me the vacuum hose has split. Which hose would it be specifically that is causing it to run lean? I want to order one off eBay and change it myself. Thanks
    S3 AMK (AKA FUTURE CLASSIC )
    Mods So Far: PCV Delete, N249 Bypass, S2K Filter, Black Side Indicators, FMIC, B5 TIP, Rear Anti Roll Bar, Polybush Upgrade.
    Mods Wanted/Planned: Wheel Spacers, Moar Silicone, 3" Downpipe, Decat, Debadge Rear Rings, Spray Front Rings, 8P/V Gear Knob, REVO!!!!!!!
    MISC: Sort Out Paintwork...
    Because It Makes No Attempt To Be Great, It Is Therefore Extremely Great.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Any of them tbh... its a bit of an open question mate..
    Typically though its the PCV ones that split... you are going to have to find out which one from the garage dude... the pipe should have a part number on it and are generally only available through dealers
    You could of course take advantage of this and do a PCV delete getting rid of most of those pipes and simplifying the whole system...
    There is a how to in the FAQs sticky on this...
    On the later AMK/BAM S3's the PCV pipes look like this...
    Can't remember off hand if the APY's are similar
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,167
    one to fpr?
    garage did'nt tell you which one then?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    May 2013
    Forest Of Dean
    No. I did ask but he said they'd have to have it back in to tell me. Think they were trying to get me to fork out the 100 odd quid to get it done by them. Will probably go for the delete, will look into it when I get home later. Cheers guys.
  1. Running lean?
    By A4-Newboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2010, 11:22
  2. Running lean!!!
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2009, 18:12
  3. A4 Cab 1.8T running lean and over revving
    By blackpool1974 in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th October 2009, 22:35
  4. running lean i think
    By slight_problem in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 12:01
  5. Can a Turbo'd car run without a DV
    By Charlies604 in forum Tuning
    Last Post: 17th March 2006, 16:45
