Badger5JMB Retrofits
Thread: Coolant change
    Jan 2005
    Norfolk
    304
    Coolant change
    Anyone one know how much coolant the A3 (TDI) requires in total, how easy a job it is to change, and if you use ONLY G12 collant or you use some G12 coolant and then top it up with water?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: Coolant change
    The G12 coolant needs to be mixed in the correct proportion for the weather etc (which is explained on the bottle from Audi / VW) not sure how much though - I'm sure someone else will be along soon.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Coolant change
    Autodata has it down as 5 litres.
    darnich's Avatar
    Aug 2005
    North Greece
    106
    Re: Coolant change
    From what I know, what is written on the bottle is the proportion of the fluid and you are not supposed to mix it with anything else
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Re: Coolant change
    VAGMAN
    Upto -25degC, anti-freeze concentration should be 40%, so in a 5ltr system, that should be 2.0ltr of G12, and 3.0ltr of water. However 5ltr total may vary on Vehicle type.
    Thats from the 4cyl turbo manual. But obviously check the bottle like others have recommended.
    AL
    Jan 2005
    Norfolk
    304
    Re: Coolant change
    thanks for that!
