Chris NottJMB Retrofits
Like Tree1Likes
  • 1 Post By [Dave B]
Thread: S3 8l, the old Rota Grid question, HELP!
    Dec 2013
    116
    Guys, Audi s3 8L, Ive got some brand new Rota Grid Drifts, 18x9.5 et38 (quite possibly THE worst et to get these in :S), running 225 tyres stretched. Fronts hit the strut the second I put them on, 0 clearance, rears, haven't tried, what spacers will I need? 15mm front, 20mm rear? Could I get away with 10mm, 15mm? (Ive heard rears can fit without spacers? I was thinking rear spacers just to have them sitting flush to the guards) I'll be wanting to lower these on coil overs very soon to, probably BC BR's, as low as they can get before looking ridiculous. But I've heard to many contradicting things, and the closest I've heard to far is 20mm front and back, 20mm on the front is going to look ridiculous
    Any one got ANY experience with these, or anything thats just 9x5 et38, and how did these fit? Pretty sure I'm going to get the front rolled anyway
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Get a tape measure?
    s3dave likes this.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    last guy i remember who had those wheels in that fitment was Donjon with a red S3. He ran 20mm spacers front and back
    Think Pats3poa also runs Rota grid drifts 9.5J but they are ET23, don't think he used spacers, in which case you could get a way with 15mm spacers on your setup
    could probably do what you like on the rear -- loads 'a room
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dec 2009
    Chichester
    218
    Rears won't be a problem with that fitment, I've got 9.5" ET35 on the back of my A3 and there's loads of room.
    The fronts are more of an issue. I need 5mm spacers with 8.5" ET35 and coilovers. You'll need more space for coilovers than struts and springs, too. Although I guess you'll have more space than me with the wider wings.
    This may help with your calculations: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit.
    Nyteryda
    Surrey
    222
    I have run 19x9.5 with 225/35/19 tyres on the front with an et of around 25 and 19x10.5 on the back with a 255/30/19 tyre and an et of around 20 .. no rubbing even on full lock and slammed on coilies
    I did try a 215 tyre on the front so the wheel could be spaced out another 5mm but it was too stretched for my liking
    Dec 2013
    116
    IMG_0441.jpg 20mm rear, 15mm front, 2-3mm clearance between inner lip and strut up front, want coil overs, advice??
  1. The old question which CAI
    By Morells in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th January 2013, 14:41
  2. help please my new oil pick up is shorter then the old one?
    By dre_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2012, 21:21
  3. The old K04 question again.
    By Beerzo in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2007, 09:43
  4. The old chestnut of running in..
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2003, 10:58
  5. Has all the old Technical Info been lost ?
    By Justin in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2003, 13:53
Tags for this Thread
