Badger5Chris Nott
Results 1 to 24 of 24
Like Tree3Likes
  • 3 Post By superkarl
Thread: How do I correctly jack the S3?
    Nov 2011
    Leeds, UK
    287
    Sorry for the multitude of questions today folks.
    I've been searching this for the last hour and am not sure what to do.
    Under the car it appears there are some square bits behind the sills that look like they would be jacking points; but looking here:
    Jacking Up An A3
    and other places, it seems that you use these "hockey puck" type rubber blocks and jack the car on the actual sill itself?!
    That just goes against everything I believe in when jacking cars! I'm unable to accept that the sill will not bend or dent.
    Is there anywhere else I can jack, or do I have to buy these blocks from Audi??
    Thanks all.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    It'll be fine mate.. That's where I have mine up. If the jacking plate is flat then underneath should be fine.
    Nov 2011
    Leeds, UK
    287
    So you jack on the sill with the hockey puck type rubber blocks?
    Oct 2012
    71
    I jack on the squarish reinforced bits you mention (jacking points) but use a standard hockey puck on the jack cup to save marking the metal. Was £4 ish on eBay and gives great grip.
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by A3_130 View Post
    The square bits on the floorpan with the round rubber bits on them? That's where I would have guessed to jack, but was worried after reading lots of conflicting information. It seems nothing is ever straightforward with these cars!
    I'm happy enough then, that I can jack the front on those points, with some padding on the jack cup. What about the rear though? It doesn't have those same squared areas, does it?
    A3 TQS
    Jul 2013
    Devon
    163
    If you Jack where the rubber bungs fit for using a lift then they will collapse in, unless you lift the whole front end together or the whole car ideally, mine are a bit bent from previous owners jacking their I guess.I have one of those hockey pucks with a groove cut out for using on the sills, was under a fiver delivered off eBay.
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by rupe View Post
    Bought a couple of those this morning, just in case, but I have to say, I am really uncomfortable with the idea of jacking on the actual sill. It just seems like a bad idea. I've never known a car be strong enough there to not cave in when jacked.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Fronts - I use a small piece of wood on top of the jack seated on the reinforced 'wavy' metal behind the sill.
    Rears - Use the wood approach again but place it across the area where the hockey pucks would mount.
    The wood stops the jack tearing the underseal and distributes the load over a larger area to stop it bending anything.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Nov 2011
    Leeds, UK
    287
    Quote Originally Posted by [Dave B] View Post
    Any chance of a photo of the points you use for clarity? And also a pic of the wood so I can gauge size?
    Cheers!
    epox's Avatar
    Oct 2012
    Glasgow
    584
    i use 400mm 4x2 under the jacking points on the cill, then put stands under thst and remove the trolly jack. back and front
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I also use 4x2 but it's a piece a little shorter, maybe 200mmish. Can get you a pic of the mounting area but it'll probably be the weekend now as it's pitch black when I'm not in work.
    > S3 225 (03) - OEM+
    View: My S3 diary
    epox's Avatar
    Oct 2012
    Glasgow
    584
    the longer the 4x2 the more it spreads the load along the cill
    mark
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    there is a point at which increasing the length of wood makes no difference
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by Alex C View Post
    is that what she told you....
    [Dave B], s3dave and Alex C like this.
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    actually it just gets painful
    Alex S3 AMK
    Nov 2011
    Leeds, UK
    287
    Well I'm out trying to jack the car and getting pretty pissed off. The rubber hockey puck blocks I bought are grooved but the groove is too shallow to accept the entire depth of the seam along the bottom of the sill.
    That's just the first problem. #2 is that the blocks also will sit right against the sill cover if I try to use them. That's not going to be ideal and I would expect damage to the outer sill.
    #3, I cannot for the life of me see ANY markings indicating where the car should be jacked. There's nothing there. Absolutely nothing. Wiped the bottom of the sill clean, got down there with a bright light etc. There's nothing whatsoever marked on the skirt.
    Help! Need this up in the air in the next hour.
    epox's Avatar
    Oct 2012
    Glasgow
    584
    put the 4x2 under the cill roughly center it on the step on the cill put the head of the jack in line withthe step on the seam and jack up
    mark
    epox's Avatar
    Oct 2012
    Glasgow
    584
    https://www.dropbox.com/sc/snoy2stm4re4oxs/WWW7g2Aqgw bit wet here best i can do, i drilled ou a bit for the head of the jack not really requied hope the link works mark
    Nov 2011
    Leeds, UK
    287
    Cheers, that's a really good idea! I've ended up just jacking on the big silver subframe bolt at each side, hehe one farthest back from front, and putting stands under the sill jacking points. I had 5 mins away from the car then went back and it suddenly all became clear.
    Was very nervous jacking on those bolts, but all my other cars have always been very strong on any subframe mountings.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,063
    Visit 16Klappe's Instagram Channel
    Jacking on the chill, you mad? Chassis legs and a low entry jack ftw.
    I quite often say I'm going to do things.
    Then never do them.
    epox's Avatar
    Oct 2012
    Glasgow
    584
    must be lucky then... timber is supported on the lip which the oe jack fits into, plastic cill is close but timber not touching.. ye cheep jack but thats only used to get the car uo then stands fitted to the side and jack removed.. used this way to replace discs calipers etc front and rear with no issues. pics were just a guide as one else had replied to the post.
    mark
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Inner sill not outer sill!
    > S3 225 (03) - OEM+
    View: My S3 diary
    Nov 2011
    Leeds, UK
    287
    Yeah the stands and rubber blocks are under the inner sill with the lip along the bottom. I rang a specialist yesterday who told me to do it this way.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Or just get the ECS jack pad kit.... Makes life way easier and is an OEM solution.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Navigation Plus! How does it fit in the dash?
    By stratos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2005, 20:30
  2. How do I tell if the car has a K03 or Ko3 Sport
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 11:48
  3. Replies: 1
    Last Post: 10th June 2005, 22:16
  4. How to gain access to the SUB-Woofer
    By FSI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2005, 16:24
  5. How high can I raise the power
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 10:05
