Volks AutosAH Fabrications
Results 1 to 30 of 30
Like Tree4Likes
  • 3 Post By slowcoach3
  • 1 Post By russwuss
Thread: cold side relocation done, now boost gauge is reading lower?
    russwuss's Avatar
    Feb 2013
    458
    Hi All,
    As title really, I've done the cold side relocation (as shown in the pic) and now the boost gauge is reading max 12 - 13 psi on full boost.
    The car doesn't actually feel like it's boosting less than before, I just wondered if this was normal?
    Boost gauge is T'd into top of the DV.
    Thanks!
    IMG_0298 by russwuss, on Flickr
    Apr 2011
    Dublin, Ireland
    621
    I could be totally wrong and probably am, but shouldn't the boost guage be t'd in elsewhere such as the manifold.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    Aug 2011
    Plymouth
    754
    Add Lavis89 on Facebook
    some people T it from the FPR, others (and me) T'ed it from the vac line that comes off the top of the DV
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What did it read before? Is it mapped?
    russwuss's Avatar
    Feb 2013
    458
    Quote Originally Posted by Lavis89 View Post
    Same here, mines T'd into the vac line on top of the DV that goes to the inlet manifold - it did read perfectly fine before, about 20 - 21 psi on full load but since doing the cold side relocation it's changed :-/
    russwuss's Avatar
    Feb 2013
    458
    About 20 - 21 psi, yep it's stage 1 r-tech remap. Car doesn't feel like it's under boosting at all.. Just can't explain the change.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Vac leak, faulty boost gauge, caught vac line feeding boost gauge, DV fitted right way round?
    russwuss's Avatar
    Feb 2013
    458
    DV is definitely fitted right way round, I'll check all the others at the weekend - hopefully will be fitting a catch can. Cheers for the tips!
    Aug 2011
    Plymouth
    754
    getting the vac line going to the boost gauge snagged is always a good shout, i managed to do it... twice... on the same day....
    RIP S3dave
    May 2004
    nr Glos
    7,175
    leaking dv?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    pressure drop through the intercooler?
    but your still reading the pressure from the inlet manifold... don't know
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    russwuss's Avatar
    Feb 2013
    458
    Cheers for replies all!
    I'll check for snags on the boost gauge feed this weekend, DV shouldn't be leaking.. Brand new one fitted in March, any easy way to check it for leaks?
    Pressure drop through intercooler is possible isn't it? I've got custom made alloy pipes for the intercooler and the cold side outlet is just welded onto there (not sure if you can see on the pic) N75 is still going to normal place on the charge pipe with the DV port blocked off.
    russwuss's Avatar
    Feb 2013
    458
    I've got loads of vac hose, so I'll T into fpr line and see if it makes a difference.
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Quote Originally Posted by russwuss View Post
    Well that was my instant thought reading your OP
    But boost gauges are normally tee'd into the top of the DV (as yours is), which is essentially reading the inlet manifold pressure which is the same regardless of whether you have a cold side relocation or not. Maybe the pressure on back side of the diaphragm/piston makes a difference... but it shouldn't.
    Alex S3 AMK
    Sep 2010
    Devon
    756
    Please don't tee into the fpr line, it needs to be left alone as you don't want anything messing with your fueling, if you do then your penis will shrivel, your hair will fall out and you will start supporting man city.
    Best guess is either something has been disturbed during the installation or it's a dodgy gauge which isn't unheard of.
    superkarl, Lavis89 and russwuss like this.
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Jul 2011
    19
    How do you know you had 20/21 psi before fitting the gauge?
    russwuss's Avatar
    Feb 2013
    458
    Quote Originally Posted by S3 zombie View Post
    The gauge has been fitted for a few months, the reading changed from 20/21 psi when I installed the cold side relocation.
    russwuss's Avatar
    Feb 2013
    458
    Quote Originally Posted by slowcoach3 View Post
    Please don't tee into the fpr line, it needs to be left alone as you don't want anything messing with your fueling, if you do then your penis will shrivel, your hair will fall out and you will start supporting man city. Best guess is either something has been disturbed during the installation or it's a dodgy gauge which isn't unheard of.
    message received haha.
    russwuss's Avatar
    Feb 2013
    458
    right, got some time today to look and think i've found the issue... the nipple under the inlet manifold was cracked, literally touched it with my hand to check the condition of the pipe and it came off........ does this mean i need a new inlet manifold or is there some other way to fix it?
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Could drill and tap it for a hose tail fitting?
    Think May still have some with a 5mm nipple in my garage from when made my inlet mani
    If interested and can find them your more than welcome to one
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    sure its broke off and not just fallen off?
    russwuss's Avatar
    Feb 2013
    458
    Quote Originally Posted by StaceyS3 View Post
    Could drill and tap it for a hose tail fitting?Think May still have some with a 5mm nipple in my garage from when made my inlet maniIf interested and can find them your more than welcome to one
    I've never used a tap in my life.... :-/Is the ones you have the same as this one? 1/4 Bsp X 3/16 = 5 mm Brass Hose tail x 1 b154 | eBay so, do I need to drill, then tap a 1/4" bsp thread and the hose tail will screw right in? :-)Sorry for the dumb questions... Brother may have one of these hose tails and taps at work but if he doesn't I would be very interested in one from you :-)thanks!
    russwuss's Avatar
    Feb 2013
    458
    Yep I'm sure.. nipple was still in the hose
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    could always block it off and T off the other ones? make sure they are clear as well
    russwuss's Avatar
    Feb 2013
    458
    now there's an idea.... i'm actually waiting for my catch can to arrive, so having the inlet manifold out the way will make it much easier.I'll be blocking off the big nipple underneath as part of the catch can install correct... ? So rather than blocking off I could run a 8mm to 4mm hose adapter to my DV and block the snapped part up?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yes, ideal...
  28. #27
    russwuss's Avatar
    Feb 2013
    458
    yes, ideal...
    Wooohooo :-) easy fix... thanks a lot Dave!And thank you Stacey for the offer of the 5mm nipple :-)
    StaceyS3 likes this.
  29. #28
    Sep 2010
    Devon
    756
    And its a good time to clean the inlet too, tut tut tut
  30. #29
    russwuss's Avatar
    Feb 2013
    458
    Two cans of carb cleaner on the way as we speak
  31. #30
    russwuss's Avatar
    Feb 2013
    458
    well that's sorted... however now the breather hose decided to snap in half when removing! arghhh!
  1. Boost gauge now fitted.
    By bowen in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th March 2012, 11:27
  2. Boost gauge only reads negative boost?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 21:45
  3. Cold Side Diverter Valve Relocation
    By grathies in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2008, 17:31
  4. Cold side relocation kit?
    By Jampublic in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2007, 20:48
