Chris NottJMB Retrofits
    Dec 2013
    32
    help with removing turbo
    can anyone tell me how to get a turbo off a audi a3 1.8t 97 i bought on off a member as mine is dead now trying to get it off so far i have got off 4 bolts that hold it to the exhaust
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    you will need to remove the Turbo intake pipe (TIP)
    and the bolts that hold the turbo to the exhaust manifold
    and the turbo oil lines
    and the turbo water lines.
    Dec 2013
    32
    can you do it from the top or does it need to be the bottom
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    from the top
    Dec 2013
    32
    just got the tip off the shaft has so much play feels like there is no middle in it
  1. Help with removing headlight
    By LiveWire in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2010, 13:34
  2. Help with removing N249
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2010, 11:19
  3. help with removing rear light cluster
    By rygon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2010, 22:25
  4. help with new turbo!
    By dappadan786 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2008, 12:58
  5. A6 2002 - fitting parrott - help with trim removal please!!!
    By milo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th August 2005, 15:00
