EM TuningBadger5
Thread: Turbo fin's
    Oct 2013
    N yorkshire
    65
    Turbo fin's
    My turbo fin's move only a little in and out with NO play up and down is this play in the turbo acceptable or is it knackered.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    I understand that a little side to side movement is fine. Slack is taken up when the oil flows past the bearings.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Nov 2013
    Heath Hayes
    952
    It all depends what kind of bearings are in the turbo. Most have sleeve bearings which use the hydrodynamic properties of oil to produce a bearing surface.These will have a certain amount of play side to side but the turbine or compressor shoudn't be able to touch the housing any where. There should be very little axial movement ( in and out) on the shaft.Some turbo's use bearings with ceramic ball or roller elements, these should have no appreciable movement in either direction.Karl.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    As said journal bearings have a small bit of play up down, no in out play should be really there..
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
