AH FabricationsEM Tuning
Thread: abs fault
    kkk
    Aug 2013
    North London
    109
    abs fault
    My abs light is on and has a fault for the pump
    Could the pump cause an intrrmittant but there more than not vibrating throught the pedal wheel snd car?
    I need to replace the pump anyway but want to know if il need discs aswell.
    Mar 2013
    bournemouth
    Quote Originally Posted by kkk View Post
    My abs light is on and has a fault for the pump Could the pump cause an intrrmittant but there more than not vibrating throught the pedal wheel snd car? I need to replace the pump anyway but want to know if il need discs aswell. Thanks
    Hi there, have you managed to repair the problem? If not let me know, it might be the abs module, i had the same issue and it was the module itself. I can repair it if you require.
    Big Al's Avatar
    Awesome GTI tuning this week!
    May 2011
    West Midlands
    282
    I have a fully working ABS pump for sale off my car, see classifieds for Ebay link.
    Classifieds: 2001Y AUDI S3 8L FACELIFT 1.8T Quattro BREAKING FOR SPARES
    Alistair
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Aug 2013
    Norfolk
    67
    Have you had it scanned for faults? I had a similar issue and the problem turned out to be a wheel speed sensor fault. A much cheaper fix than a new abs pump
    kkk
    Aug 2013
    North London
    109
    the fault comes up as a pump issue and googling leads to be the wireing, fuses or the pump and i checked the wireing and fuses.
    i have a pulsating pedel but not all the time which leads me to believe it is the pump bearings causeing this.
  1. limp mode and abs fault
    By smith4130 in forum Diesel forum
    Last Post: 12th March 2007, 22:50
  2. ABS fault - vag com - purley/croydon area
    By Dracoro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th February 2007, 22:38
  3. ABS Fault Light...
    By JGrant1285 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2006, 09:50
  4. ABS Fault 0 any ideas?
    By Wicked666 in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th August 2006, 07:18
  5. ABS fault - now i'm desperate!
    By imported_mc119856 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2005, 22:58
