Sky InsuranceEM Tuning
    A3 TQS
    Jul 2013
    Devon
    123
    Question Bose amp replacement
    Hi, Having a bit of trouble with the bose setup in my a3 quattro, getting horrible distortion sound from the front passenger door speaker.I have had the bose amp out the back, taken it apart and re-soldered the joints as I read that can be a fix sometimes, I have done this twice now just incase I didn't get one of them the first time around, but it's still sounding bad
    My question is; do I have to replace it with another amp from an 8L or are their other models I can use the amp from to broaden my search for one and is their anything else I should be looking at incase it's not the amp?
    AK47UK's Avatar
    Sep 2013
    253
    I think the speakers have a weird impedance so you are very limited by aftermarket amps, I may be wrong but I thought this was the case.
    A3 TQS
    Jul 2013
    Devon
    123
    yes your right you can't use an aftermarket amp without changing everything, I want to replace it with another bose amp, just wondering if any other audis use the same amp as the 8L?
    Mar 2013
    Devon
    398
    Have you checked the door speaker to eliminate it? Maybe swap left to right.
    Not sure which other Bose amps are compatible, but you could have a crack at changing the transistors in your amp if you have basic soldering skills.
    A3 TQS
    Jul 2013
    Devon
    123
    I haven't tried swapping the speakers over yet, will give that a go I think, are the door cards fairly straight forward to get off?
    I could have a go at swapping bits in the amp but maybe stabbing in the dark a bit?
  1. Bose Amp Replacement Question
    By Plastic_Badger in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2013, 18:58
  2. Bose Amp Blown I need a replacement
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2009, 12:22
  3. 2 ohm replacement speakers for use with Bose amp.
    By hooley in forum In-Car Entertainment
    Last Post: 10th March 2007, 18:41
  4. BOSE Amp Replacement
    By papoutsis_y in forum In-Car Entertainment
    Last Post: 31st January 2007, 01:54
  5. Replacing Bose Amp for Main Speakers
    By rweerasi in forum In-Car Entertainment
    Last Post: 12th July 2004, 14:34
