Chris NottMonster Motorsport
    Oct 2013
    10
    Turbo issue on 2001 s3
    Hi all, got engine light on on my s3, had it scanned and got 3 codes. My main concern is P1297 - fault location - turbocharger/throttle valve, hose connection pressure loss. Probable cause - hose connection. I know that seems pretty self explanitory but I'm no mechanic and would like to check it myself?
    Anyone else had this code before?
    Also sometimes after I've started it the turbo doesn't work but if you turn off ignition and re start it it works ok. i always assumed it was a split hose or similar as once you hit 4500rpm the turbo kind of drops off like the pressure has gone.
    Also got code P0420 which is related to the cat....
    Any help greatly appreciated.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    have you viewed ross-tech for their code and descriptions?
    here>>
    P1297: 17705 - below 5'c temps, common bug in software, std and mapped.
    17705/P1297/004759 - Ross-Tech Wiki
    P0420: 16804/P0420/001056 - Ross-Tech Wiki
    Is this a std car or modded?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Oct 2013
    10
    Hi thanks for reply. Will definitely check the links out. The car has had a remap and has a forge dump valve and coil packs. It has no real history and I've not had it long but this is what I've been told by previous owner.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    smoke test to confirm leaks present or not..
    17705 is common post remap and cold temp software issue (map) IF no leaks present.
    limp mode is the result
    bill@badger5.co.uk
    Oct 2013
    10
    Thanks very much for your help, much appreciated. I'm guessing limp mode is no turbo?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    limp mode = actuator pressure... so 5psi ish
    bill@badger5.co.uk
  1. Newbie With S3 Turbo issues!!
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2010, 16:17
  2. Turbo issues
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2009, 10:06
  3. Turbo issues???
    By Scottynic in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2009, 19:36
  4. Buying a K04 turbo for S3(2001) or TT
    By Guano in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2008, 10:03
  5. Turbo Issue Questions
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2004, 08:46
