JMB RetrofitsChris Nott
    Oct 2012
    434
    Fitting a new rear brake caliper
    I am about to fit a used rear caliper and just wondered what the order of play is? i.e fit caliper, wind piston all the way in, bleed then press the pedal so it makes contact with the pads i presume handbrake mechanism get's set automatically (pads are are about half worn).
    Thank you
    Ian
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    make sure the bleed nipple is free on the new caliper before fitting.
    clamp the flexi, remove old caliper fitting, replace with a new washer when fitting.
    if your fitting old pads, no need to wind all the way back, enought to get the pads in.
    then bleed as normal.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Oct 2012
    434
    Cheers for that
    Iain
    bigray's Avatar
    Oct 2013
    leeds
    147
    check seals before fitting. and make sure the handbrake latch sits same as the other side, sounds daft but i replaced one of my calipers recentlyand the cable catch is higher.
    so cable pulls different lengths on the hand brake it self
  1. fitting porsche or s4 brake calipers
    By gruf in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th August 2008, 18:48
  2. Rear Brake caliper piston tool
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2008, 11:29
  3. s4 rear brake calipers
    By batty in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2008, 20:35
  4. S6 Rear brake caliper..help!
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2007, 13:06
  5. new rear brakes
    By kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2006, 21:30
