Sky InsuranceJMB Retrofits
    Jan 2013
    Somerset
    Prop Shaft Removal - Help
    Hi all,
    So i recently had the rubber on my prop shaft exploded and left the prop shaft hanging off. i recently replaced this but this morning it did it again! so does anyoone know what i have to remove to be able to get the prop shaft off completely and just let the car drive on front wheel drive? really need my car for work and cant have it off the road for ages again! Any help appreciated.
    Jamie
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    After having broken my old S3 for parts, I have experience of taking the prop out (parts all sold). I would recommend you try taking your car to a local garage where they have a drive on ramp. Remove the rear & centre exhaust section. Remove all the prop bolts and centre prop support bolts to remove prop. Refit exhaust. Disconnect Haldex connector.
    If you try to do this on a drive you make struggle to get the exhaust off and back on again. The prop bolts are very tight, you have to undo them with car on drive on ramps or otherwise the prop just spins whilst spannering. Plus the prop is very heavy, long and awkward to lift out of the way, so get some mates to help if you can.
    Good luck sorting this out!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Jan 2013
    Somerset
    Thank you for your help! Will give it a go tomorrow and update how i get on!
  1. prop shaft help s3
    By s3_sid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2013, 21:23
  2. Help ! How do I move the prop shaft out of the way to fit Dp
    By dre_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2012, 13:46
  3. remove prop shaft to fit down pipe ?
    By melon454 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2012, 09:43
  4. HELP PROP SHAFT REAR SEAL LEAK !!!
    By audi avant in forum General Technical / How To
    Last Post: 3rd August 2010, 21:39
  5. Help!! Anyone know where I could get a Prop Shaft?
    By brettp in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2010, 14:44
