Chris NottJMB Retrofits
Results 1 to 8 of 8
Thread: Vcd codes???
    Oct 2013
    N yorkshire
    65
    Vcd codes???
    Hi my s3 has started with a whining whooshing noise??? Plugged it in to vcd lite and no codes would a knackered turbo or a leak in the system bring up some codes. The car is down on power but not smoking!!! Typical just passed mot on Monday and this happens carnt drive it I have heard if it is the turbo it could suck bits into the engine and knacker that!!!!! Help!!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    No actual codes for a fecked turbo but there may be codes relating to the result of a fecked turbo... normally when there is a boost deviation...
    Sounds more like a boost leak tbh... smoke test would be the next thing to get done
    <tuffty/>
    Oct 2013
    N yorkshire
    65
    Smoke test how do I do that just by looking at it??? Glad YOU reply you know what your on about. Put a another topic on the form it was called turbo issue maybe???? And somebody put a link for a you tube vid of a car with the same noise and he says it's the turbo!!?? Could ya have a look and see what you think. And my car smoke looks ok!!! Please help tuffty!!!!
    Oct 2013
    N yorkshire
    65
    Oct 2013
    N yorkshire
    65
    Drove it about 15 miles 2 day with no power. Stripped it down to the turbo and is all still there with no play in the fins somebody said my cat might have broken up blocking the exhaust??? Is there anyway of checking this????
    epox's Avatar
    Oct 2012
    Glasgow
    599
    intercooler pipes intact?
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Oct 2013
    N yorkshire
    65
    Yes they look ok what I can see how do they join is there a pipe that goes across the front of the car??
    epox's Avatar
    Oct 2012
    Glasgow
    599
  1. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th April 2010, 07:38
  2. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2010, 17:58
  3. VCDS coding for tails
    By tcardio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2010, 17:45
  4. Help! Passenger's window won't close! VCDS Code.
    Last Post: 3rd January 2010, 01:07
  5. VCDS Codes
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th December 2009, 13:01
