Chris NottVolks Autos
    Nov 2013
    84
    oxygen sensor heater circuit
    hello
    my ecu gives fault code: oxygen sensor heater circuit bank 1 sensor 1
    i replaced the sensor and the problem not solved
    what can fix this problem?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    did you replace the correct sensor, you may have 2 depending on engine.
    new or used part ?
    fitted correctly ?
    damage to wiring/block?
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Nov 2013
    84
    hello
    its used o2 sensor
    i see damage to the wiring from the ecu near the o2 sensor
    they have cut and stripped together with glue.
  1. Oxygen Sensors Removed
    By freeflying in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2012, 01:10
  2. Lambda sensor/oxygen Sensor
    By GemmaLouise in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 12:36
  3. Pre Cat Oxygen Sensor - Where to Buy?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2011, 09:45
  4. Intermittent Oxygen Sensor
    By guinness in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 13:29
  5. oxygen sensor problem, help pls.
    By A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 19:40
