Volks AutosJMB Retrofits
    Oct 2013
    29
    Boost gauge vent install
    hello all,
    i am trying to install my new boost gauge and vent hold in the drivers side vent above the light switch.
    i have managed to remove the vent itself and the casing below the steering wheel but i cannot actually remove the vent from a wire in the back that much be the light source for the slider to turn vent on and off. where does this unclip?
    also where can i run the vacuum tube through to this area?
    thanks
    May 2013
    Channel Islands, Jersey
    82
    did you have any luck with this mate?
    Audi S3 AMK, Badger 5 Tip with Cone and Heat Shield, Forge 007P (green spring), de-cat pipe
  1. OSIR TT/A3 boost gauge vent pod :)
    By martinivw in forum For Sale/Wanted - Audi Cars
    Last Post: 27th May 2013, 20:42
  2. How do I remove the air vent to install a boost gauge?
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2012, 14:27
  3. Newsouth Performance Audi A4 B6/B7 Turbo Boost Gauge Vent Pod Kit
    By auroan in forum For Sale/Wanted - Miscellaneous
    Last Post: 31st January 2012, 12:59
  4. Boost gauge centre vent install?
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2009, 21:51
  5. boost gauge vent pod
    By mastayoda in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2007, 13:16
