Volks AutosChris Nott
Results 1 to 8 of 8
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    Exhaust issues think
    well this is really starting to get at me now
    as you can see in the pic there are 3 bolts, the one that my finger is pointing to keeps coming loose and then blows the gasket, so again my car sounds like a tank
    can anyone give me reason on why this keepo happening and wht to do to solve this
    also when we have had it in the garage there is thought that there should be some sort of bracket (turbo braket) is this right if so what does this look like and where should it go
    your help is muchly appreciated, as this is getting me to the point of getting rid of this car
    1.8Q sleeper all the way
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Support bracket should be under the turbo to the block, try using nordlocks on the offending bolt or get someone to tack it in place with a welder...
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    I have rung audi and they are saying that there isn't a gasket for my vehicle????????????????
    im pretty sure there is??
    yeah I had thought about tacing, nor locks it that a good thing??
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    also am I right in thinking that I will be able to undo the 3 bolts and slide the new gasket in??
    and can I only get the gasket from audi or is there anywhere else I cn get it from like europarts
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    from Audi or TPS only for a gasket about a fiver... yes undo all 3 bolts remove the old one, and the new gasket will slide in, is the exhaust fitted correctly with no undo stress on the turbo?, also they dont look like genuine bolts , get them too
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    I think the exhaust is fitted properly, I know that where the exhaust is joined in the middle there is abit of movement
    don't know if there should be something supporting it in the middle
    got a gasket ordered for 4 quid,
    they are the bolts that were in when I got the car, if I bought new genuine ones could it cause a problem with these bolts that are in and not genuine????
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    No you need genuine ones in, the ones you have could be stretching with the heat causing the gasket failures
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    got you brilliant I will order some now and then get it all replaced and pop upto the garage and get them tacked on thanks dave
  1. exhaust issues
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2011, 11:32
  2. Exhaust Issues, Help Appreciated.
    By Curt in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2010, 22:37
  3. Exhaust issues
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th January 2010, 16:23
  4. New exhaust - what do you think?
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2006, 18:26
  5. New exhaust wot u think?
    By fallmonk in forum General Chat
    Last Post: 8th February 2005, 20:51
