Chris NottEM Tuning
Results 1 to 9 of 9
Thread: clutch kit
    Nov 2013
    Dundee
    55
    clutch kit
    I have recently bought my s3 02 plate facelift now the clutch is fine I think I thought it has slipped on me once but maybe it was me ricin the clutch not sure , so have been trawling around looking for clutches etc , would this fit on my carhttp://www.larkspeed.com/index.pl?p=DT775FR1224&a=i
    cheers
    Ross
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Gimme the Reg and i'll check the available options for you.
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Nov 2013
    Dundee
    55
    Na02eyy
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by rosscopeeco13 View Post
    Na02eyy
    LUK - 624 3034 34 - ECP PART NUMBER - 637441710 ( 3 PIECE CLUTCH KIT )
    LUK - 415 0111 10 - ECP PART NUMBER - 336440420 ( D.M.F )
    VALEO - 835058 - ECP PART NUMBER - 633440080 ( SOLID FLYWHEEL CONVERSION )
    HAPPY SHOPPING
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    check out euro car parts always good deals going on & they supply LUK.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Nov 2013
    Dundee
    55
    Thanks guys
    Nov 2013
    Heath Hayes
    951
    Dont know why people keep quoting Euro car parts. If you need it on the day and have to goto the shop then ECP , otherwise car parts for less. It's the web only shop for ECP.
    checked out the quoted part numbers for the clutch parts above. obviously the ECP number works on car parts for less.
    LUK - Euro Car Parts UK’s No.1 Car Parts Retailer £181.20
    LUK - Car Parts 4 lessCar Parts Retailer £132.99
    LUK - Euro Car Parts UK’s No.1 Car Parts Retailer £323.94
    LUK - Car Parts 4 lessCar Parts Retailer £236.99
    Valeo - Euro Car Parts UK’s No.1 Car Parts Retailer £419.94
    Valeo - Car Parts 4 lessCar Parts Retailer £290.99
    So clutch and DMF from ECP £505.14 and from car parts for less £369.98 a saving of £135
    The solid flywheel conversion kit £128.95 difference.
    personally I would stick with the DMF option as originally installed by Audi, unless you are planning to upgrade the power in which case a Sachs organic with a DMF is a good daily driver clutch option.
    Karl.
    Nov 2013
    Dundee
    55
    Thanks Karl appreciate that I will be staying with dual mass flywheel mate as that was the way it was fitted thanks for the info so good to be able to ask guys in the know
    Nov 2005
    UK
    1,689
    Quote Originally Posted by desertstorm View Post
    Karl.
    Theres 2 different types of DMF the difference being what model year it is. I suggest ringing them & confirming the DMF you have selected is correct.
    wanted for 8L S3:
    Milltek system
  1. New gearbox and clutch kit. More problems....Please Help!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2008, 07:13
  2. Clutch Kit - Which one? - How much? - Where?
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2008, 17:44
  3. s3 clutch kit
    By c16wko in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2008, 19:06
  4. Non VAG clutch kits
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2006, 16:39
  5. grip force heavy duty clutch kit
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2004, 04:44
