Just had the s3 on a local guys vagcom,
had the engine management light come on when i was driving a bit spirited,
these are the faults i got..
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 01236
VCID: 387FDBE01847DEDE6C3-5122
WAUZZZ8L821001231 AUZ7Z0A1869429
3 Faults Found:
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-00 - Mechanical Malfunction
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-00 -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
VCID: 3E73CDF83A63E0EEA6F-4B00
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-10 - Electric Circuit Failure - Intermittent
27-10 - Implausible Signal - Intermittent
I'm guessing the two boost related ones are due to the dump valve the previous owner has fitted, which will be getting swapped out for a full recirc one rather than to atmosphere,
the coolant temp gauge stopped working for about 5mins but is now fine, but will get a new one on order incase,
any ideas on the rest?
haven't got round to checking my cluster for the esc bulb being blown/missing, but would the abs faults throw that light up?
hence giving them a reason to remove it?
cheers
Coding: 10710
Shop #: WSC 01236
3 Faults Found:
P1296 - 35-00 -
Coding: 18448
Shop #: WSC 01236
2 Faults Found:
cheers
