EM TuningAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Gary_808
Thread: 2001 s3 vagcom results..
    Dec 2013
    131
    Just had the s3 on a local guys vagcom,
    had the engine management light come on when i was driving a bit spirited,
    these are the faults i got..
    Address 01: Engine Labels: 06A-906-032-BAM.lbl
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    VCID: 387FDBE01847DEDE6C3-5122
    WAUZZZ8L821001231 AUZ7Z0A1869429
    3 Faults Found:
    17608 - Boost Pressure Control Valve (N249)
    P1200 - 35-00 - Mechanical Malfunction
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-00 -
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E73CDF83A63E0EEA6F-4B00
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-10 - Electric Circuit Failure - Intermittent
    27-10 - Implausible Signal - Intermittent
    I'm guessing the two boost related ones are due to the dump valve the previous owner has fitted, which will be getting swapped out for a full recirc one rather than to atmosphere,
    the coolant temp gauge stopped working for about 5mins but is now fine, but will get a new one on order incase,
    any ideas on the rest?
    haven't got round to checking my cluster for the esc bulb being blown/missing, but would the abs faults throw that light up?
    hence giving them a reason to remove it?
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    17608 can be related to having an N249 bypass... this fault code is because the ECU tried to dump boost using the N249 and didn't see the expected drop in boost... it assumes a mecanical malfunction of the system
    17704 is normally related to the coolant temp sensor (CTS) which is a common failure point...
    17705 is a tricky one... could be genuinely a leaky valve (as you infer you have an atmos type valve this could be it) but its also a know bug in the ECU software and typically appears when the colder weather is here (5deg or less ambient temps)... this fault normally occurs on cold start and results in limp mode until the ignition is cycled... this is normally removed in most re-maps...
    <tuffty/>
    Dec 2013
    131
    Thank you made it alot clearer, would any of these bring the light up?
    i think mine may of had the bypass done as I seem to remember finding some bits in the boot that look like what you remove,
    That clears up 17608 and 17704,
    I'll investigate the dump valve situation, and the 17705 as it was cold last night 3-4 degrees, but have also noticed if I hold part throttle when coming off a round about some times it sounds like the d/v is sticking I'll investigate.
    Dec 2013
    131
    Had a gander and investigated a little, the parts I found were the old d/v
    bit currently has this fitted..
    I'm guessing the bypass also hasn't been done..
    going to order a new d/v tonight and maybe some hose to do the bypass.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    oh dear god!!!....
    Some people shouldn't be allowed near cars ... get a new top hose too dude as you won't want to plumb it in the way they have... put it back to stock location, get the right hoses and hopefully all will be good...
    I despair sometimes I really do...
    <tuffty/>
    Dec 2013
    131
    I've got myself a top hose kit and forge 007p on order,
    Hopefully that issue will be cleared up,
    <tuffty/> likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,167
    atmos wooshy ftw, I mean Fail...
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  1. My VAGCOM Results - URGENT
    By Boydie in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th July 2010, 02:02
  2. Vagcom Results
    By Pinola in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2010, 21:46
  3. Vagcom results after N249 bypass and reversed DV
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 11:03
  4. VAGCOM results
    By kitpayne in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2009, 21:20
  5. VagCOM Results - Mazzy test drive
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2006, 03:35
