JMB RetrofitsVolks Autos
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    AVS or inspection service ?
    Hi,
    Can anyone tell me what the difference is between the 2 please ?
    I think the AVS is with longer service intervals (>20k miles) and long life oil ?
    Inspection service is annually carried out with standard audi spec oil ?
    is this correct ?
    also after having an AVS service what should the service indicator show
    I understand it should adjust according to driving style but would you expect to see it increase/decrease after 700 miles on from the reset ???
    thanks
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: AVS or inspection service ?
    The indicator takes a while (good few 1000) before diplaying a "true" next service indication.
    AVS circa 20K about right, mine 18K and I do that yearly .... the inspections should be doe yearly as a check, if a AVS isnt due.
