EM TuningJMB Retrofits
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    874
    Add Vex182 on Facebook
    Standard S3 anti-roll bars - bushes and sizes?
    So it's time to replace the S3's front drop links and anti-roll bar bushes. I have changed the rear drop links and noticed the bushes on the rear are looking skabby. The front ones appear to have a plastic collar that has broke off the brushes. Can I remove them and replace them with polybushes without the plastic collars. Anyone know what size bushes are needed for the front and rear? Is it easy to change them? The rears don't look to bad if I drop the rear box.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Vex182's Avatar
    Apr 2012
    Hinckley
    874
    Anyone please help?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Stock sizes are 19mm front, 14mm rear. BUT, some people have reported having them 1mm different or so, whether thats down to them being special or there are in fact different sizes i dont know. As always, check, and double check.
    Its a simple job either way. Perhaps consider new bolts and collars if yours are badly corroded
    Aug 2012
    My front ARB collars cracked and were causing a knocking noise. I ended up removing both collars and fitting 18mm bushes (febi 27304) I think, then placed 2 jubilee clips on the outer side to prevent any lateral movement. Worked really well! Best bet is to measure the bar, I believe they came in several sizes. Hope that's of some help!
    Dan
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    Quote Originally Posted by danambler View Post
    Dan
    Yes it is.
    I replaced the bushes and it was a nightmare because the sizes may vary from 18 to 20mm. I wasn't able to buy the correct ones until I measured the anti-roll bar diameter...
  1. Anti roll bar bush sizing
    By Grale1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2012, 13:36
  2. Anti Roll Bar Bush Kit - Info
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 09:46
  3. ARB Uprated Anti Roll Bar Bushes
    By *Unkle* in forum A2 forum
    Last Post: 15th October 2009, 18:28
  4. Shake, Rattle and Anti Roll bar bushes
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2008, 21:08
  5. HELP!! 8P S3 front anti-roll bar bush HELP!!
    By jonnyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 11:14
