Sky InsuranceJMB Retrofits
    Nov 2013
    22
    Help with wipers please
    My 1999 a3 has an issue with both the front and rear wipers...the fronts seem slow no matter what speed position I set the stalk to and the rear wiper seems to stop for a brief second several times during each wipe...any help please guys
    Mar 2013
    Devon
    611
    Suspect theses are two separate problems.
    Slow front wipers is usually caused by corrosion in the linkage.
    You can clean and grease the linkage, you need to remove the wipers, then the scuttle panel. There are 3 screws holding the linkage and motor in, and the electrical connector.
    Once the linkage is out of the car you will see two c clips holding the pins the wipers connect onto into the aluminium casting, if you remove these you can tap the pins out. They will most likely be badly corroded and can be cleaned up with a light oil and wet+dry paper.
    Grease the pins up, reassemble and be amazed at how much faster your wipers are!
    Nov 2013
    22
    Ok so I'll try that for the fronts, any ideas what could be causing the problem with the back wiper?
  1. Help with insurance please....
    By robbie5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2008, 17:54
  2. Crashed New A3 3.2 in an hour! Help with Bumpers Please!
    By magnus911 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2007, 10:36
  3. Help with ICE please!!
    By Tonya Rosey in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2007, 09:15
  4. help with wheels please???
    By raymie in forum General Chat
    Last Post: 2nd September 2006, 18:38
  5. Help with codes please
    By addamsmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2006, 09:19
