Volks AutosSky Insurance
    Feb 2013
    20
    Arrow Rear break pad replacement
    Hi guys,
    Just replacing the rear pads. Got the calliper of fine, pads out. Now the problem I've got is getting the calliper to go back, I've been for a calliper winding tool applied it to the calliper to wind back in, it will not turn:s
    I'm right in turning it clockwise? I've removed the brake fluid cap. Tried it with hand break off as well as on. Also tried to loosen the break bleed valve, it won't budge.
    What I'm I doing wrong?
    Thanks in advance
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    they can be tight to go back in. or the piston could be seized.
    handbrake has to be off. and you don't need to undo the bleed nipple.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Feb 2013
    20
    How can I check if its seized?
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Quote Originally Posted by shaunf84 View Post
    Not sure if this is the right way but a few gentle pulls on the brake lever. Get some to do it whilst watching if the piston pushes out of the caliper.
    That way you know the piston isn't seized.
    The piston can be a ar$e to wind back in. Abit of persuasion it will wind in.
    I'm also sure it's clockwise.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
  1. Rear break pads but which I ones?
    By nealb in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2012, 13:00
  2. Rear Brake Pad Replacement.
    By a3a3a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2011, 03:34
  3. Rear brake pad replacement
    By stevebuba in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th June 2010, 20:09
  4. Scraping Noise from rear? Brake and pad replacement? or stone stuck?
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2009, 19:29
  5. Rear Brake Pads & Disc Replacement
    By maddoggydawg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 20:43
