JMB RetrofitsBadger5
    dan-quattro's Avatar
    Sep 2008
    Staffs
    149
    Overboosting Error Log & Limp Mode
    Hi all,
    My 2001 S3 AMK has started to throw a wobbler...feeling some hesitation on boost and it will totally drop off before the turbo has fully kicked in to give absolutely no boost whatsoever and drives like a standard 1.8. This occurs in 3rd gear, can't remember the revs, sorry.
    Had it on vagcom and shows 'Charge Pressure: Maximum Limit Exceeded'.
    Take car back out and boost seems to be there in all gears again, so is very puzzling.
    Something is intermittent it appears as it gives me boost up until 3rd gear and it's there that the problems begin.
    possible N75 fault?
    currently sat on my drive and had boost when I got home, on way to work in the morning I'm betting it will be lost again, frustrating.
    Audi S3 2001 AMK, Milltek Cat-Back Exhaust, 18" TT Wheels, Black Leather Recaro, x1 Very Happy Driver
    Sep 2008
    Staffs
    149
    Just ran vcds lite and showing:
    Along with the 'Charge Pressure: Maximum Limit Exceeded' it also says:
    P1555-35-10 intermittent
    Readiness 0000 0000
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    17963/P1555/005461 - Ross-Tech Wiki
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    Its plausible its the N75... have seen them play up before... ideally you want to be logging boost and N75 duty but VCDS lite won't allow you past block 20... over boost can be due to iffy maps, iffy N75 pipes, sticky actuator/wastegate and of course an iffy N75... logging would help diagnose ut if you know someone with a 1.8t you could try swapping out the N75...
    <tuffty/>
    Sep 2008
    Staffs
    149
    Cheers bud,
    My garage have offered some live data logging so will need to get in touch with them I think, and maybe they could also try eliminating some of the possibilities.
    Was just seeing if any of my symptoms seemed obvious to anybody, strange how it's intermittent
    Jul 2013
    159
    Hi, do you have a forge dv? I had the same error code (yes it could be many things) but mine was caused by the dv not being tightly screwed together.
    Sep 2008
    Staffs
    149
    Quote Originally Posted by cammage08 View Post
    Not that im aware of, i have noticed when boosting the noise is louder than i remember, similar to the noise on a video posted to youtube showing his dv being knackered, so wondering if its that
  1. 3rd Gear logs for Chaz20vt - Limp Mode
    By Alex C in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2012, 16:07
  2. A3 TDI 140, HELP Overboosting, Limp Mode!
    By Scholey3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2011, 22:56
  3. Turbo overboost & limp mode
    By Lo x in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2011, 12:05
  4. Overboost condition 2.0 tdi Vagcom results inside limp mode
    By kdotman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2011, 22:34
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
