Results 1 to 9 of 9
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    Follow JoeeS3 On Twitter Visit JoeeS3's Instagram Channel
    how hard is it to remove s3 turbo
    How hard is it and approx how long would this take? With the right tools etc
    Joe
    i'm not a genius...i'm a learner
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    A pain. Head off job is easiest way!
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    Can you get to it easier from underneath with a ramp or not?
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    could someone give me an approximate labour cost for removal and fitting cost of an turbo on an s3 so i dont get ripped off?
    thanks
    joe
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Most Garages will take the head off, some take the engine out..so you are looking at an hefty bill either way, if the head comes off you will need an head gasket set minimum, then there is the timing belt, probably water pump while its off, all the wet stuff, oil, coolant etc
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    would i be better of doing it with someone else myself who has a good idea of what they're doing? using this method s3 8l turbo removal....
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    I thought you already had it off?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    I dont think any normal garage would touch the cylinder head to remove a turbocharger.
    The Audi manual method certainly doesnt mention removing the head, and i'd imagine autodata wont mention it either.
    Some specialists on here seem to do it, as its a bit less awkward, but these folk work on the car a lot and have picked up their own tweaks and methods of doing things. Also, i really cant see that much time saved once you've done all the extra work involved in changing the cylinder head gasket, timing belt etc etc. Ofcourse if these bits are needing done anyway then it could pay to have it all done together, but thats not always the case.
    Personally, theres NO WAY i would entertain touching the cylinder head to remove the turbocharger. Major engine surgery to remove an anciliary component is something i just wouldnt be doing. I'd rather pull the whole motor out the car complete if it really came down to it.
    Audi Specify 620minutes to remove and refit the turbo on the S3, vs about half that on a normal A3.
    TD5 Land Rover Defender build
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    I've taken the turbo off without taking the head off, well thats before i went Top mounted BT.
    I ended up making soon tools and it added a few hours to the job
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  1. Omg how hard is it to remove the rear wiper!
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2012, 16:04
  2. how hard is it to change the turbo on a318t agu engine
    By mk1kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2010, 21:29
  3. how hard is it 2 fit a turbo 2 a non turbo 1.8 v5
    By rik_t2005 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2009, 19:18
  4. 1998 a6 1.9 tdi vacuum pump replacement - how hard? where is it?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd September 2005, 11:53
  5. How hard would it be to turbocharge a 90 quattro
    By brokensaab in forum Classic Audi Forum
    Last Post: 14th December 2003, 12:51
