had my car put on vcds today (Cheers FactionOne) to see what faults it brought up
looked bad on 1st inspection
First Scan
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Monday,20,January,2014,17:03:22:58573
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: ****
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 8N0 906 018 BP
Component: 1.8L R4/5VT 0002
Coding: 10710
Shop #: WSC 33278
5 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - Intermittent
17545 - Fuel Trim: Bank 1 (Add)
P1137 - 35-10 - System too Rich - Intermittent
17743 - Engine Torque Monitor 2
P1335 - 35-10 - Control Limit Exceeded - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 35-10 - ****** Setpoint not Reached (Over-Advanced) - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 9008
Coding: 01104
Shop #: WSC 00673
1 Fault Found:
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 R
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 01444
Shop #: WSC 00000
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15214
Shop #: WSC 00134
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
77-10 - Internal Supply Voltage - Intermittent
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
2 Faults Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
29-00 - Short to Ground
00774 - Level Control System Sensor; Rear Left (G76)
31-00 - Open or Short to Ground
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00134
End ---------------------------------------------------------------------
so had them removed went for a spirited drive to see what popped back up and was fairly pleased
Second Scan
Monday,20,January,2014,17:42:26:58573
Coding: 10710
Shop #: WSC 33278
Readiness: 0000 0101
Coding: 18448
Shop #: WSC 01236
Coding: 00041
Shop #: WSC 01236
Coding: 01104
Shop #: WSC 00673
Coding: 01444
Shop #: WSC 00000
Coding: 15214
Shop #: WSC 00134
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 01236
1 Fault Found:
Coding: 00201
Shop #: WSC 00134
quite pleased to be honest as i was expecting alot more to be wrong with it, will get it scanned again in a few weeks see if anything pops back up.
