Badger5Monster Motorsport
Thread: help with codes
    audiholic ste's Avatar
    Aug 2013
    164
    help with codes
    Well I've not had a good month and I'm after some help . My s3 standard as far as I know apy engine has gone into limp mode . I've had it scanned and this is what has popped up 16795 ( p0411) 17963(p1555) and 16955(p0571) any help comments or advice would be great cheers . Steve
    Lewis583's Avatar
    Mar 2010
    870
    You tried Google'ing the 5 digits fault codes?
    Quote Originally Posted by Ross-Tech Wiki
    16795/P0411/001041
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuel Pump Relay (J17) faulty
    • Hoses/Pipes to/between Components faulty/clogged
    • Secondary Air Injection Pump (V101) faulty
    • Secondary Air Injection Pump Relay (J299) faulty
    • Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    • Check Fuel Pump Relay (J17)
    • Check Hoses/Pipes to/between Components
      • Check Secondary Air Injection Hoses/Pipes for Carbonization
    • Check Secondary Air Injection Pump (V101)
    • Check Secondary Air Injection Pump Relay (J299)
    • Check Secondary Air Injection Solenoid Valve (N112)
    17963/P1555/005461
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    • Reduced power output
    • Limp mode
    Possible Causes
    • Boost Pressure too High
    • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    • Charger Pressure Control defective
      • VNT (variable nozzle turbo): nozzles stuck
    • Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
    16955/P0571/001393
    16955/P0571/001393 - Brake Light Switch (F): Implausible Signal
    Possible Symptoms
    • Malfunction Indicator Lamp (MIL) active
    • Glow Plug Indicator Light active
    • Brake Light(s) not working
    Possible Causes
    • Wiring and/or Connectors faulty
    • Fuse(s) faulty
    • Wrong Brake Light Bulb installed (21W instead of 5/21W)
    • Brake Light Bulb(s) faulty
    • Brake Light Switch (F) faulty
    Possible Solutions
    • Check Wiring or Connectors
    • Check/Replace Fuse(s)
    • Check/Replace Brake Light Bulb(s)
    • Check/Replace Brake Switch (F)
    Special Notes
    • Brake Light Switches (F) have the reputation of breaking quite often.
    HTH
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Aug 2013
    164
    Cheers fella . I didn't google anything I'm crap with computers and all that stuff . To be honest didn't even think you would get that info . I live in the dark ages ... I'll check hoses and stuff . The brake lights are working but I'm unsure if one has been changed . The car has just been for it's mot .
  1. New here and need help with codes.
    By 98Quattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2008, 23:43
  2. Please help with codes..airbag.
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 02:01
  3. Help with codes + ESP/ABS issues
    By 69COU in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th June 2007, 13:26
  4. Help with codes please
    By addamsmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2006, 09:19
  5. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
