AH FabricationsEM Tuning
Results 1 to 10 of 10
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    Cooling system ?
    Anyone had problems with there cooling system ?
    My engine light came on i took it down to my techie at Audi (a mate). Who looked it over & couldnt find any problems with the pumps. The system was slightly over full so this was reduced & the pressure cap replaced (the car was not overheating). Engine light then went off everything seemed fine until yesterday when it lit up again. I imagine its the same problem but has anyone expierenced this before. The cars a 2002 S3 with only 27k on the clock.
    Any help would be apprciated.
    Matt
    Jun 2003
    Hythe, Kent
    1,180
    Re: Cooling system ?
    When you say engine light do you mean the engine management light? If so, what makes you think the problem is to do with the cooling system?
    Kev.
    Nov 2005
    UK
    1,679
    yes engine management light. the car was hooked up the Audis computer system & the fault code given indicated coolling system.
    Nov 2005
    UK
    1,679
    the engine symbol which lights on the speedo
    Nov 2005
    UK
    1,679
    the fault came up as malfunction in the cooling system.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    If you can get the actual fault number that would help narrow it down.
    ECU can't detect a fault with the main pump, but there may be a code for the electrical one which circulates coolant after you switch the car off.
    Also it can detects coolant sensor and wiring probs.
    Nov 2005
    UK
    1,679
    Under Fault / notes detected
    the following is displayed on the screen print:
    17704 P1296 035
    Malfunction in cooling system
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Okay doke. I'll take a look at me list when I get home from work for you.
    Nov 2005
    UK
    1,679
    thanks, much appreciated
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I've had a quick look at the manual and all it says is refer to the "checking coolant system" area.
    Of the two electrical items in that section, I'd check the "continued circulation pump". It describes how to check if its working or not. I've included the document for you (or your mecanic) to look at.
    CLICK ME
    Its a PDF document. Hope it helps a bit.
    The other electrical item is the radiator fans, but if these weren't working, you'd probably experience overheating in traffic.
    If it was the coolant temp sensor, then you'd get a different error code to the one you are seeing.
