Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    Question S3 windscreen washer pump location?
    Hi guys,
    I have a problem with my S3.
    My windscreen washer pump is not working, and when I try to use it its fuse just blows (and then the wipers don't work either).
    I think it is a pump problem (I hope not the wiring, it looks okay) and I want to replace it.
    The trouble is... which one is the pump I am looking for?
    Here is a picture of my engine bay:
    Number 1 is definitely a pump, but is it the windscreen or the headlights one?
    There is also something connected to number 2, but I cannot see it clearly.
    There is also a connector behind the bottle, but I think it is just the sensor.
    Any advice? I couldn't find anything that cleared it up for me.
    Thank you!
    epox's Avatar
    Oct 2012
    Glasgow
    481
    front pump is for headlight washers, rear pump is for front and rear screens. iirc its a pain to change.
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    epox's Avatar
    Oct 2012
    Glasgow
    481
    unplug the pump power ,then try and use the washer if the fuse does not blow you have knocked it off if it blows..its somthing else.
    pumps are a push fit into the bottle
    mark
    stripped mine out bumper off , headlight out, wee bits disconnected thar are to the rear of the bottle....... load of work because the headlight washer was not working and it was a fuse!!!!!!! felt like a tolal fa....y for not checking that first..
    mark
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    Thank you Mark!
    So you mean it's nº3 what I'm looking for? I would give it a try this weekend.
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    Yep, it is definitely the pump.
    Ordered a new one for 20€. I hope it arrives before the weekend.
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    Quote Originally Posted by ManuGD View Post
    It didn't.
    But now it's here
    epox's Avatar
    Oct 2012
    Glasgow
    481
    now comes the good bit!! fitting it
    mark
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    So this weekend I fitted my new pump.
    First of all we need to make some room to reach the pump location, and there it is.
    We first unplug the connector and then unplug the pump from the bottle pulling it gently.
    The windscreen washer liquid starts to come out the bottle.
    Then we need to put the new pump back in and there it goes but...
    Wait, what is that??
    Oh sh**, the cable is trapped under the engine mount.
    So we unbolt it, raise the engine a bit and free the cable.
    Yes, it looks bad. And it gets even worse because I can see the copper cables.
    I wonder if that also "helped" my car to blow so many fuses.
    So I taped the cables until I can get them properly fixed. At least the pump works fine now.
    To put everything back again I just did the reverse process. Plug the pump to the bottle, plug the connector, and bolt back the stuff I removed before. Refill with liquid and go :D
  1. NEW GENUINE VW AUDI SEAT SKODA WINDSCREEN WASHER SYSTEM PUMP 1K5955651
    By A4_MaJiK in forum For Sale/Wanted - Audi Parts
    Last Post: 7th November 2013, 15:20
  2. Windscreen washer pump.
    By norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2013, 20:09
  3. Leaking Windscreen Washer Bottle......
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2005, 15:09
  4. Smell from windscreen washer
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2005, 20:03
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
