    May 2013
    Glasgow, Scotland
    195
    Opinion needed pls
    Hi guys,
    been fighting a loosing and expensive issue with my 03, AUQ, 1.8t Leon Cupra. I know this is ASN but the likes of tuffty, prawn, klappe, badger5 are all on here and not to discount anyone else but you guys seem to know the 1.8t inside and out !!
    I have posted a few time with this issue and not really got anywhere, but today l was getting a small weld on my backbox done and noticed something new !!
    There are 2 lambda sensors on this car, but the 1 in front of the cat has a massive long cable ?? Its been tie wrapped up so as not to hang down, but surely this cant be correct !!
    So my question is, if its the wrong lambda sensor could it cause a hesitation around 2k revs??
    No codes at all, mpg down a little 22.4mpg on a short city run(just changed thermostat tho)
    Cheers guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    Generic Bosch wideband lambda probes (from GSF/ECP etc) have a longer cable than the OE part (same sensor but cable is a specific length for the OE application)
    I have one of these sensors on my S3... cable is cable tied behind my heatshield... perfectly ok...
    The wideband sensors have different plugs to the narrow band ones so no danger of mixing them up... if you have a different manufacturer from Bosch then tbh I would advise only using a Bosch one...
    <tuffty/>
    May 2013
    Glasgow, Scotland
    195
    <tuffty/>
    Thanks tuffty spot on as usual !!
    means im still searching then.... FML !!!
  1. Opinions needed on a quote i got for............
    By darkspin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2004, 14:56
  2. Opinions needed please. Any mechanics in here?
    By imported_AudiOwner96 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2004, 10:04
  3. Brakes... Opinions Needed
    By jonathanA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 01:03
  4. Advice Needed Pls
    By RAV in forum General Chat
    Last Post: 25th February 2004, 12:29
  5. Advice Needed Pls
    By RAV in forum Diesel forum
    Last Post: 25th February 2004, 11:56
