Monster MotorsportBadger5
Results 1 to 21 of 21
Like Tree5Likes
  • 1 Post By Biggied
  • 1 Post By BENJAMIN
  • 1 Post By Gops
  • 1 Post By jojo
Thread: Back in an 8l quattro just in time for winter.. ReIntro..
    Biggied's Avatar
    They called him mellow yellow.
    Feb 2006
    Scotland
    202
    Hi All,
    Ewan from Dundee,
    I used to be on here a bit a few years back when I had my Imola Yellow 8l S3 which I Sold as I needed house funds, I've had a couple of RWD Mazda sports cars, an A4 2.8 V6 Quattro since but always wanted another 8l, I wasn't happy with the examples of S3s within my budget so have opted for an 2000 8l A3 Quattro 1.8T, 61k miles and in far above average condition all round, I picked this up 2 weeks ago.
    The car came with a Rica engineering remap (any further info?) and S3 Cat back which the owner claimed to be 215hp, as its a pre facelift AJQ 180hp engine I think it only has a K03 so not sure what power it really has but either way its only a number, The car pulls well and from memory doesn't feel like it would be far behind my stock 210 S3, I think it seems to boost lower down and with a bigger kick but runs out that bit sooner in the revs.
    As the car still has a standard appearance I've decided to go for a stealth stage2 tune keeping with the K03 & drivers side throttle layout, this will allow me to fit parts as I go (its a daily) while keeping all the final options open (stock K03s, Hybrid or K04-001)
    Anyway further mods have started this weekend with the fitment of a Toyosports 3" downpipe & decat which coupled to the existing standard S3 exhaust is a great vaule budget exhaust option IMO.
    I'll be getting the unspeakable out the way first before doing any more but will be following the forum in the mean time for more ideas etc.
    Ewan.
    Sandra likes this.
    210hp 8L S3 quattro.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,446
    Hi ewan, welcome back, nice car. Look forward to seeing you at some of the local meets. x
    Scotland
    Boost fiend
    Dec 2008
    Swansea
    215
    I'm pretty sure being the AJQ 180 engine, it will have the KO3s turbo as standard. If its about 215 bhp I'm more inclined to think that, as KO3 runs out of puff at about 195bhp.
    Easy way to check if its a KO3s is to see If there is a silencer on the cold side of the turbo, failing that, check the little blue tag on the turbo itself for the part number.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Jul 2011
    wiltshire
    137
    I'd be interested to see if it has a ko3s as I have the same model and engine, could you clarify te cold side silencer?
    Biggied's Avatar
    Feb 2006
    Scotland
    202
    I've yet to have a proper look but i know theres no silencer although I think you get the Ko3s without them, and I'm pretty sure all pre facelift/pre 2001 A3 1.8t quattro have Ko3 that's why I havn't really looked.
    Ewan.
    Jul 2011
    wiltshire
    137
    a letter explaining the differences between K03 turbos from Borgwarner who make them
    All the following turbos have the same installation dimensions and
    thermodynamical performance. The differences are only in the actuator that
    opens the turbine bypass valve:
    K03-011 (5303 988 0011) 150 hp, 65 N actuator
    K03-026 180 hp, 85 N actuator
    K03-035 180 hp, 85 N actuator
    K03-044 150 hp, 65 N actuator
    K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
    K03-049 150 hp (Sharan/Alhambra), 65 N actuator
    The 180 hp versions have an actuator with a higher opening force due to the
    higher exhaust gas pressure (which is a consequence of the higher boost
    pressure). Otherwise the valve would be pushed open by the exhaust gas
    pressure.
    The following turbos are a further development (since 2000) and have an
    improved and slightly larger compressor while using the same turbine (still
    with the same installation dimensions):
    K03-052 180 hp, 85 N actuator
    K03-053 150 hp, 85 N actuator
    K03-058 150 hp/180 hp, 85 N actuator
    Consequentially, putting a 180 hp turbo on a 150 hp engine will not bring
    about any change in performance, but putting on a K03-052/053/058 instead of
    the older versions will bring a slight improvement in engine efficiency.
    Not sure if any use, but made for interesting reading
    BENJAMIN's Avatar
    Mar 2011
    471
    1.8t quattro;
    -AJQ engines have a K03.
    -ARY engines have a K03S
    16Klappe likes this.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Feb 2012
    Rutland
    132
    Ben - you have an 8p s3 now?!
    2001 AMK S3 in Goodwood Green
    Nov 2013
    Dundee
    55
    Hi Ewan nice car mate , I am also from dundee , I have just purchased a dolphin grey 02 plate s3 and I'm loving it this is the first s3 I have owned had a 1.8 t a few years ago , but never a quattro , looking forward to getting it out in the snow as my merc will be tucked away until after the winter lol
    BENJAMIN's Avatar
    Mar 2011
    471
    Quote Originally Posted by dancuz View Post
    Yep, not had it long!
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by Nick101 View Post
    No Nick, not true at all. There are silenced and unsilenced K03s turbos. Also the silencer is on the hot side.
    k03 "s" doesn't actually exist, it is just a name given to a certain group of part numbers.
    I quite often say I'm going to do things.
    Then never do them.
    Biggied's Avatar
    Feb 2006
    Scotland
    202
    Hi Rossco,
    I think I might of seen your car about, good to see another local member. If you need sombody local to look after your car I've just recently finished 10 years employment as a Technician at Audi but I'm now working at Kevin Pirie and Son on East Dock Street, if you ever need anything just pop in and ask for myself.
    Ewan.
    BENJAMIN's Avatar
    Mar 2011
    471
    Quote Originally Posted by 16Klappe View Post
    Jardo, it gives me great pleasure to tell you that you're wrong. The silencer is on the cold side (comp housing), it's not on the turbine housing (exhaust housing)....
    superkarl likes this.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Quote Originally Posted by BENJAMIN View Post
    I was clearly drunk when I wrote the aforementioned post, you obviously know I know that. As does everyone else.
    Then never do them.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Haha! Style it out jardo...
    BENJAMIN likes this.
    BENJAMIN's Avatar
    Mar 2011
    471
    Quote Originally Posted by Gops View Post
    Poorly executed though. Lol
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    He blames it on the goose!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,502
    I blame it on his aftershave!
    Nov 2013
    Dundee
    55
    Quote Originally Posted by Biggied View Post
    Hi Rossco,
    Ewan.
    Hi mate Ewan I'm sure I know you are you not martin bells mate , did you not do the timing belt on my golf gti 150 about five months ago .
    Rossco
    Biggied's Avatar
    Feb 2006
    Scotland
    202
    Quote Originally Posted by rosscopeeco13 View Post
    Rossco
    Guilty as charged mate, how you finding life in an S3 now?
    Ewan.
    Nov 2013
    Dundee
    55
    It's great mate I was looking for one when you worked on my golf as my everyday car a new merc coupe isn't much cope in the snow lol , I still have your number so will be in touch shortly think I might need a clutch in the future and a few other bits I'm glad I waited to find a decent one one of the best cars I have ever owned
  1. Time for winter wellies
    By kevbu in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2010, 06:32
  2. Not Starting, just replaced timing belt
    By Seifer780 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th May 2009, 20:24
  3. Car hit just in time for edition!!!
    By joshW in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2007, 01:38
  4. step back in time for Audi-sport
    By Rev-head in forum General Chat
    Last Post: 22nd July 2007, 12:55
  5. HELP a3 quattro just died!
    By cawood in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2007, 20:38
