Badger5Monster Motorsport
Results 1 to 7 of 7
    Oct 2013
    Bristol
    BAM ecu to APY ecu
    Hi guys , i know it's been mentioned before that you can't use an APY map on a BAM ecu but could you swap the whole ecu over with associated clocks and bits and if so then what would the difference be , the APY ecu is remapped to 270 brake.
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    So I understand this... you have a BAM and want to fit an APY ecu???
    Basically don't.... you will be replacing your existing setup with an inferior one all to get a remap that you can buy for 250 quid... and... the map may not even work on the hardware you currently have due to all sorts of reasons...
    You will lose wideband control, EGT protection and VVT by going backwards technology wise...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,191
    Quote Originally Posted by Greener View Post
    cheers
    why?
    wiring different also
    all to save you getting a map done??
    not advised
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    APY is narrow band and BAM is wideband which is better
    I swapped from APY to BAM
    What your wanting to do will cost a bit of money and for what a stage 2 remap cost i would rather get it mapped rather than swap everything over
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    You can give me the bam ecu if you want but seriously it's like stepping back don't do it, just get it mapped instead!
    Oct 2013
    Bristol
    Thanks guys , i'm a total Audi virgin and didn't know if this was possible or even worth doing as i found a APY ecu remapped to 270bhp for £130 . Glad i got the right site for info here and guess i'll just get a remap/air filter/exhaust but first my clutch is on the way out so should i go paddle , heavy duty , fast rd or standard . Eventually i want about 300bhp from the engine . By the way , if anyone wants help or info on rover/mg then give me a shout
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    No real need to go paddle tbh... there are quite a few clutch discussions on here... its a subjective topic... the OE clutch and DMF setup is more than up to the task but obviously depends on how you drive and the sort of journeys you do...
    If you want something a little more 'launch' proof then you can use a Sachs paddle plate with a normal DMF/OE cover for OE fell (light pedal) but more bite... I have run this setup for a while and love it but obviously paddle plates do wear more than organic... I got about 20k from my plate but the (new when I fitted them) cover and DMF will go again though on a new paddle plate
    Stick to OE (LuK from GSF is the same) if you don't plan to launch it everywhere...
    <tuffty/>
  1. Looking for APY ECU 8L0906018N
    By h100vw in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2013, 13:29
  2. Audi S3 APY ECU and Clocks - Matching
    By jimbob442 in forum For Sale/Wanted - Audi Parts
    Last Post: 11th July 2012, 11:42
  3. Help please Early APY ecu needed ASAP
    By woody.dub in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2011, 19:21
  4. audi S3 ECU early APY
    By woody.dub in forum For Sale/Wanted - Audi Parts
    Last Post: 25th May 2011, 08:08
  5. APY ecu
    By Madeley in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2010, 08:49
