EM TuningVolks Autos
Like Tree1Likes
  • 1 Post By ant schof
Thread: metalic rattle squeak when let of accel intermittent?
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    hey all, since ive had the s3 occassionally at very low speeds while turning, below 10mph iv had a weird squeak rattle noise that happened very occassionally.. thought nothing of it but today it got alot worse?
    if im driving at 30 then let of i get a rattly/squeaky/nut in camshaft kinda noise... its still intermittent btw but obviously annoying ?
    thinking maybe aux belt tensioner or aircon pump bearings???
    its a 1999 apy s3, with 144000 any help?
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
    Jan 2011
    80
    Hi Justarn ,
    Check out your alternator clutch pulley as mine made a similar screech noise before it went on my S3 . If you remove the multi v belt the alternator clutch pulley should only move one way , to do this you will need to lock the alternator from moving using a screwdriver or such . Hope this helps ,
    Ant
    justarn likes this.
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    hey ant, thanks i'll have a look. it had a new alternator just before i got it apparrently, in april, but prob a crappy pattern part...
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    been flat out at work, have a look the weekend.. anyone else had a similar experience when there alternator clutch gave up?
  1. Engine/exhaust rattle when letting off??
    By S3 Daniel in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 19:24
  2. Squeak when I start the car
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2007, 13:13
  3. clunking when letting of brakes
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2006, 21:27
  4. Internal rattles/creeks when cold!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2006, 09:11
  5. Metalic Rattle on Startup
    By AUDIDOO in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2003, 11:00
