Badger5JMB Retrofits
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    Car doesnt want to move?
    Hi guys, having an issue with my car at the moment now its cold, when i put it into gear and go to drive away it stalls (i have to really rev it to get it to go) putting the clutch back down doesn't really seem to help that much however it starts fine and is happy as larry on tick over.
    Any ideas as my neighbors are going mental, reving it at 5am
    also on a side note my hose from the inter cooler piping to the dv keeps poping off, (its not beaded) any idea s on a DIY temp fix?
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,599
    Fault codes?
    <tuffty/>
    Nov 2012
    Kent
    459
    Just scanned it with torque, it came IP with P0133 slow response to o2 sensor? Any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,599
    OBD-II Trouble Code: P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
    Torque's not the best tbh as it uses generic codes... a VCDS scan will be better...
    Not found this code on Ross Techs wiki though so not sure...
    The link above suggests there is an issue with the lambda...
    <tuffty/>
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,389
    Quote Originally Posted by Tim_Attard View Post
    for intercooler pipework..... Run a bead approx 5mm wide of JB cold weld around the end to create a bead. It works I've done it before about £9 from auto factors IIRC if you put too much on don't worry it grinds or flats down just like metal.
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    Nov 2012
    Kent
    459
    ok i might pop it to ben for the pipe and a look over as its needing a lot of tlc atm anyone else have any ideas?
  1. Buying new car, Info wanted
    By Bankzi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 18:54
  2. Anyone got an s line rear valance for 3 dr car they want to sell?
    By latta1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2011, 13:24
  3. Replies: 0
    Last Post: 14th July 2003, 09:42
  4. IF YOU WANT YOU CAR ON THE CLUB STAND AT GTI-i....
    By RichA3Turbo in forum Major UK Events
    Last Post: 9th May 2003, 19:03
  5. MOVED: My new car
    By amoffat in forum General Chat
    Last Post: 2nd April 2003, 19:22
