Chris NottVolks Autos
Results 1 to 7 of 7
    Oct 2012
    birmingham
    197
    oil coming out of turbo
    got the car in the air today and noticed oil coming out of the turbo where the intake pipe comes into the turbo is this normal car is a s3 1999 apy with 72000 on the clock .thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Doubts its from the turbo... oil in that area is almost always from the cam cover gasket....
    <tuffty/>
    Oct 2012
    birmingham
    197
    just had cam cover gasket done not log ago aswell as sump gasket?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    I'd just check it again then... I always use a little sealant round the half moon gasket and in the transition from the cam tensioner/front cam cap to the head... I'd check this isn't leaking... if clean then I'd clean the area with brake cleaner and see what comes back if anything...
    Have you had any other work done? the only other thing that it could typically be is a leaking oil feed union on top of the turbo... beyond that it could be oil from the PCV going into the TIP (sign of worn rings) or the turbo itself but the seal normally goes the other way and leaks through the hotside
    Is this all over the outside or does it appear to be coming from inside the TIP?
    <tuffty/>
    Oct 2012
    birmingham
    197
    will spay brake cleaner over it tommorow an get a better inspection done and report back tommorow thanks..tuffty
    Oct 2012
    birmingham
    197
    did have the timing belt kit done aswell not long ago
    matt blowen's Avatar
    Jul 2013
    staffordshire
    111
    Add matt blowen on Facebook
    I have the same problem but my oil is leaking from oil return pipe or delivery pipe,
  1. Is Call of Duty 3 coming out on the PC?
    By Caesium in forum General Chat
    Last Post: 20th December 2006, 16:40
  2. Help - Front seats need to come out (S3)
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2006, 20:40
  3. Whens the new RS3 coming out ?
    By Wish in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2003, 19:33
  4. ESP turned off - no power coming out of a bend
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 14:47
  5. Come out, come out, where ever you are...
    By amoffat in forum General Chat
    Last Post: 25th March 2003, 14:50
