Chris NottAH Fabrications
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: 2.0t coil packs - spark plug question
    TQS Collective
    Apr 2012
    54
    Thumbs up 2.0t coil packs - spark plug question
    Looked about on google already and the info varies alot. Coil packs are going on my 1.8t AJQ, replaced one, symptoms went and are now coming back. Original packs on 127k so im switching them for the 2.0tfsi ones.
    Question: What spark plugs should i use on a standard mapped K03s turbo 180bhp and what should I gap them to. Also, what would plugs andd gaps would be recommended for a stage 1 or 2 map?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    0.7mm and BPR6EIX plugs will be fine..
    <tuffty/>
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    Apparently they run better at 0.8 on the S3 & they actually come gapped at 0.8 but you choose.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Never noticed anything different performance wise between 0.7, 0.8 and 0.9 (tried them all) and when we tested on the dyno there was no performance difference at all...
    I had an occasional misfire under boost on my dyno queen map during the summer that went away after changing the gaps from the 0.85 I was running back to 0.7mm...
    All the hype over TFSI coils is a myth IMO... they could well be a slightly better coil than the 20v one but I ave seen them fail on TFSI's recently and this means they are still just a coil pack...
    <tuffty/>
    badger5 likes this.
    TQS Collective
    Apr 2012
    54
    Well the ecs ones work out cheaper from awesome so theyll do, cheers for the info
    Alex C's Avatar
    Lizard, Cornwall
    2,566
    what's the service/replacement interval on spark plugs for a standard S3?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by Alex C View Post
    Platinum or irridium plugs are typically 30-40k... Pretty sure VAG spec 40k service on plugs.. but then they do think AVS is a good idea too
    I use BKR7E's (copper plugs) now and change them every 10k... more relevant on a mapped car (7's vs 6's)
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Just buy either standard PFR6Q's or BKR6E's and fit them as they come out of the packet.
    TD5 Land Rover Defender build
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,533
    Just to let you know.. One of my tfsi coilpacks failed! So they're no better, just slightly longer In my opinion!
    TQS Collective
    Apr 2012
    54
    Yep theyre taller, I needed the car for work this week so i just stuck them in without adaptors but theyre really securely wedged. I rang volkswagen in ruislip to get the oem adapters and they redirected me to a new TPS in Hayes (Uxbridge). Looks like VAG are directing customers there to get the parts now, all 4 adapters came to about £6. I wonder if thats the trade price or retail, cheap either way.
    BTW I already run BKR6E's, as far as I remember they're pre gapped to about 0.81mm.
    TQS Collective
    Apr 2012
    54
    <tuffty/>
    Just an update, I ordered these plugs but they dont fit. The bolt part that the socket fits onto is too big, they dont fit down the spark plug tunnel. Need to order a different set. BKR6EIX
  1. How to change coil pack/ spark plugs on 1.6 FSi ?
    By HenrikMeister in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2013, 18:55
  2. Help Shuddering, Low power. Coil Pack? Spark Plug?
    By TomCrox41 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2012, 20:27
  3. coil pack/spark plugs
    By knoxie in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2012, 21:55
  4. spark plug question
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2007, 21:48
  5. coil packs and plugs
    By 20vtdaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2007, 23:02
