AH FabricationsEM Tuning
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Spark Plug/Coil Pack change
    Hello everyone
    just wondering if there is a tutorial for changing the spark plugs and coil pack? Had a quick look earlier and I'm not sure about disconnecting all the hoses etc to get to the coil pack.
    my coil pack is the type that's bolted down
    thanks
    CazzaVR's Avatar
    Sep 2013
    Gloucestershire
    165
    Just undo the hex bolts etc on the black metal frame that holds the hoses. Think there are 5 or 6 from memory. No need to undo hoses etc as they all lift out of the way once the frame is loose. Then, just unplug the coil packs and pull them out. You may need to carefully prise them up with a large flat head screwdriver if they're tight.
  1. How to change coil pack/ spark plugs on 1.6 FSi ?
    By HenrikMeister in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2013, 18:55
  2. Slight hesitation, already had a coil pack changed, any ideas?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2008, 17:11
  3. 4 Spark Plugs & 4 Coil Packs Later...Car Still Stuttering
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 22:18
  4. Desno IK20 Spark Plugs - Should I Change the Spark Gap?
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2007, 17:14
  5. Help - Coil Pack changed but still not running right!?!?...
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2006, 19:58
