Monster MotorsportChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By IrishDave
Thread: Limp Mode (with codes) help
    Nov 2013
    West Midlands
    Question Limp Mode (with codes) help
    Hey guys, wish my first post could have been on a better note but I've had my S3 about a month now. It's gone into limp mode 4 times within that time. As soon as I turn the engine off then on again it's fine.
    Got a friend to run the codes on it and this came up. The car is remapped by one of the previous owners as I have a receipt from r-tech from 2010 which included a forge 007p and pipercross panel filter so that may be something to do with it? The car runs flawless and the boost really is something else when it's working, which is like 95% of the time.
    It's pretty obvious I'll be needing a new diverter valve but just wondering if you guys have any other insight into what I would need to do to fix it before I take it into an Audi specialist.
    Oct 2013
    durham
    34
    maybe you dv is leaking causing overboost?
    epox's Avatar
    Oct 2012
    Glasgow
    484
    dont think the forge d.ump valves do to well, most ,seem to think audi dv is as good if not better....not to costly fron audi...
    would do a search incaese im incorrect.
    vcds is great for these cars
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Jun 2011
    Great Melton Norfolk
    1,340
    Change the diverter valve for a standard one re scan and clear codes.
    Apr 2011
    Dublin, Ireland
    566
    Seems pretty similar to the fault codes I got on mine. I got the first 2 on the list plus others. Had only just fitted a new oem recirc valve. Still haven't got to the bottom of it but the car runs with the cam position sensor unplugged although it takes a few turns of the key to get it started.
    My problem is I think there is a short/break in the wire running from the cam sensor to the ecu.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    Nov 2013
    West Midlands
    Was hoping it was something as simple as the DV. I'll change that and then if the problems continue look into the cam sensor.
    I've had a quick search for the standard DV and some people say it struggles with a mapped car... Would a brand new 007p be the next best option?
    Oct 2013
    durham
    34
    007p better option standard dv's a crap but what i would do is take urs off and test it there are vids on youtube to show u how to do it like this one diverter valve test - YouTube
    Nov 2013
    West Midlands
    Will give it a go tomorrow, cheers guys
    Apr 2011
    Dublin, Ireland
    566
    @willmad89.
    I am affraid you are wrong in what you say. The standard valve has been proven to work better than the 007p.
    westcoast a3 likes this.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    check for leaks - 90% of the time its a leak from the inlet manifold to PCV pipes
    smoke test ftw
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Oct 2013
    durham
    34
    Quote Originally Posted by IrishDave View Post
    @willmad89.
    well iv went through 2 standard ones now got a forge oo7p never had any problems with it
    Apr 2011
    Dublin, Ireland
    566
    That you may have. They should be changed yearly if running higher boost than standard, yet they are still proven to work better.
    Oct 2013
    durham
    34
    well not sure on others but like i say i prefer the 007p and you get a better noise too
    Apr 2011
    Dublin, Ireland
    566
    Function over Fashion.
  1. Help with limp mode problem
    By Chris-gsxr in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th July 2013, 13:12
  2. Audi A4 Auto - Help with DTC codes - Car going in Limp mode
    By Winchmore in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2012, 15:34
  3. Audi A4 Auto 1999 - Car goes in Limp Mode - DTC light - Code help #Sheffield
    By Winchmore in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th May 2012, 14:37
  4. a3 2.0tdi 8p limp mode, anybody in bolton area with vag com who can help??
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 21:43
  5. My A3 went into limp mode last night, help?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2010, 07:49
