Chris NottEM Tuning
Page 4 of 4 FirstFirst 1234
Results 121 to 158 of 158
Like Tree55Likes
Thread: Off to Bill's for a few tweaks so we've been busy
  1. #121
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by beachbuggy View Post
    Original 2275 is rated at 18lbs at 74% at 1.8 pr ..At 246 grams , assumed 24lbs it's running 72% at 2.3pr. It is the limit though! Compressor map stops at 25lbs..
    So russ' is performing way beyond what the comp map dictates using garretts 10hp/lb airflow?
  3. #122
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    be as many version as I can think of! 4/6/8/10/11 blade configurations are all possible. The 2283 7+7 that I'm using now was designed so the dreaded surge was eliminated. Once we've tested Gops version a decision will be made on which we run.. But as we are at the flow limit of the physical size of the compressor I think all gops might do is be more effecient or not ie flow the same but be in a better or worse % effeciency which will reduce or increase the charge temps which may aid timing .
    One me thing is for sure a nice set of 630cc will go well with these
    who has the 7 + 7 2283 wheel? Gazz's?
  4. #123
    Sep 2010
    Devon
    756
    Gaz does, I think irish dave does too but don't quote me. .
    Badger 5 tuned 340 bhp / 350 lbft sleeper
  5. #124
    Apr 2011
    Dublin, Ireland
    619
    Yeah I do also, but am having a load of issues with the car at the moment. Until I get these sorted I wont know how well it works on my set up. Although instead of water/meth inj I will be running a 10% meth to petrol mix.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
  6. #125
    beachbuggy's Avatar
    Surrey
    1,744
    All k04 hybrids since earlier on this year have had the 7+7.. I don't like the 6+6 version as in the k04 it surges..
  7. #126
    Apr 2011
    Dublin, Ireland
    619
    Any idea what turbine wheel we settled on for my hybrid. Was it the tfsi or rs6
  8. #127
    beachbuggy's Avatar
    Surrey
    1,744
    well yes and the 2283 which is a 35lb wheel makes near 400bhp in a Tfsi and easily over 370bhp.. The ttrs wheel is rated at 41lbs but has seen 470.. So I think it's not quite true to say lb*10=bhp as we adding performance with wmi which obviously BW never accounted for.
  9. #128
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by IrishDave View Post
    When did you buy it?
  10. #129
    Jan 2012
    Kilmarnock, Scotland
    343
    I take it if mine has 7 'dual blades' thats a 7+7?
  11. #130
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by vroomtshh View Post
    Yes.. it's the same physical size as the original 2283 just the extra set of blades.
  12. #131
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by slowcoach3 View Post
    Ok I'll look into that, unisettings worries me a little but sure I can get my head around it. Is that to reduce the idc % of the '550's'?
    yes
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  13. #132
    Apr 2011
    Dublin, Ireland
    619
    Bought in July.
  14. #133
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Compressor flow.... if maf's reading accurately, and I have a question on that as it read very different numbers for same boost between runs (ecp maf!) so I dont know what to believe..
    either its 243g/s and wmi ign making the rest of the power... or its 262g/s I also logged + wmi contribution Both peaks at 1.4-1.45bar >6krpm
    bill@badger5.co.uk
  15. #134
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    I think on extreme setups pushing boundaries and using chemical cooling and timing airflow goes out the window.
    Either way, its awesome.
    I thought it was cool that its running at way beyond the compressor map in terms of power.
  16. #135
    RIP S3dave
    May 2004
    nr Glos
    7,156
    maf's aside.... they usually under read on expected divide 0.8 g/s guide when making these "high" power figures, and its wmi contribution.
    often seen high g/s on cars without power to go with it...
    hybrids Need wmi to achieve the claimed numbers (or exceed them) in my experience.
    devils own basic wmi kit.. + solenoid upgrade ftw
    Gops likes this.
    bill@badger5.co.uk
  17. #136
    Sep 2010
    Devon
    756
    ^ definitely not an aem progressive kit my controller died as soon as we needed it to work rip it out and add in some devil's own bits and back on track!
    The maf was weird sometimes it correlated 100% correctly and others it was as out of sync as my singing
  18. #137
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    That's why I've asked our dearest bill to pop WMI on my car when it's in and Dan I've got the 550's.. Should be enough on this setup?
  19. #138
    Sep 2010
    Devon
    756
    Very sensible with the wmi! My kit was a used one I picked up for about 50p with 20ltrs of meth, turns out the controller didn't work you'll be fine though especially with a devil's own kit. 550's should be enough. my 550's were acting strangely, say they were maxed out at 340 when they should be good for a fair bit more. I don't think they are fake but they're not quite correct lol
  20. #139
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Were they new? Just had a gearbox rebuilt for me! Getting along now after abit of bad news!
  21. #140
    Jan 2011
    66
    Any idea at the moment Dan how much this entry level hybrid will be and if it will be available as an off the shelf complete unit.
  22. #141
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by wild willy View Post
    I do, but I'm not allowed to advertise which I would be doing if I was to tell you that.
    Prawn and olly quattro like this.
  23. #142
    Feb 2012
    1,085
    Would you be able to pm me a price please. Im still so undecided on what route to take and the more i look into it the more confused i get, is a manifold crucial to this. I decided to leave my standard on due to poor manifold options. And just had the engine rebuilt etc. Thanks. Daz
  24. #143
    Apr 2011
    Dublin, Ireland
    619
    Yes a manifold would be crucial. Unfortunately we are all waiting for a reliable aftermarket manifold that works.
  25. #144
    RIP S3dave
    May 2004
    nr Glos
    7,156
    hmmmm
    Gops, s3gazz, slowcoach3 and 4 others like this.
    bill@badger5.co.uk
  26. #145
    Feb 2012
    1,085
    Bill are they as big of a job to fit as a relentless? Head off etc as ive literally just got mine back rebuilt. Thanks
  27. #146
    Jan 2011
    66
    I'll pm you instead, the mean buggers, you've earned a free advertising pass in my eyes for services to Turbo's.
  28. #147
    Aug 2010
    bradford
    1,252
    Nice bill and yes Karl my turbo has the 7+7 blade in it mate and my final numbers where 349bhp & 315fltb
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  29. #148
    Aug 2010
    bradford
    1,252
    hmmmm
    wonder if my number will change with this nice piece of kit hehe
  30. #149
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    hmmmm
    Oh yes!
  31. #150
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    B5 and Frankenturbo using jbs china-folds, must be good.
  32. #151
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by daz-20vt View Post
    they fit like OE ones do. turbo to manifold bolts from the top with real spanners and sockets!! lol
    still an awkward job on a quattro k04 car tho.. turbo hides some of the mani to head bolts.
    its not difficult to fit compared to "others"...
    russwuss likes this.
    bill@badger5.co.uk
  33. #152
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    From the pics I believe it's fairly heavily reworked around the collector and head flange, but from what I've understood, the quality of the casting and material is outstanding.
    Really looking forward to the results from these Bill, hopefully it'll be the key ingredient everybody has been looking for!
  34. #153
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Have they got over leaving sand stuck inside the runner walls....
  35. #154
    Apr 2011
    Dublin, Ireland
    619
    hmmmm
    Finally.
  36. #155
    Apr 2011
    Dublin, Ireland
    619
    Also how will these compare in regard to flow to "other" manifolds on the market.
  37. #156
    Sep 2010
    Devon
    756
    Getting tested over Xmas dude. .
  38. #157
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Santas testing it on his sleigh...
    Gops, Jason.s and slowcoach3 like this.
  39. #158
    RIP S3dave
    May 2004
    nr Glos
    7,156
    there is only one other.... lets face it..
    we know what it is... its shiney and tubular
    On 'others' testing (+year ago) this style of manifold is supporting good hybrid power.
    I dont rely on 'others' testing although I have their data and logs as we have been sharing info for many many months now, and it correlates. I do want to do my own, test car testing, which is planned for Xmas period..
    I know it works.. but I want to provide my own test data on a known car (our lupo)
    Gops and wild willy like this.
    bill@badger5.co.uk
  1. Off to Bill's on 16th for remap
    By minimatto in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2012, 13:39
  2. TDI 110 lost the turbo for a few minutes????????
    By benny-g in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2009, 23:11
  3. Sent the S4 in for a few jobs that have been building up,.......
    By Dan Gliballs in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2008, 00:22
  4. Bodykit for you few who were asking..
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th September 2007, 13:56
  5. Replies: 4
    Last Post: 10th April 2007, 14:32
