Volks AutosMonster Motorsport
Results 1 to 8 of 8
Thread: ko4 turbo?
    Nov 2013
    ko4 turbo?
    I currently have a ko3s turbo on my audi a3 1.8t sport, Ive had stage 2 remap not got a print out of what bhp its running but will do, My turbo is currently whistling really loud when i hit boost in every gear not sure what it is, someone said my turbo is on its way out, I cant find a decent ko3s turbo and dont really wanna buy a second hand one as i dont know if its been ragged or anything.
    Would a ko4 fit straight on my car, Ive got front mount and new downpipe and a miltekk straight through
    would i need to change downpipe?
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    If you mean the K04 from an S3 then you will need to change exhaust manifold, TIP, injectors, coolant and oil lines, downpipe, MAF housing and get a custom map..
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    ...oh and sort the charge pipe work out a bit too as the K04 is in a slightly different position to the K03... and mod the coolant hard pipe to the heater hoses.. there are a fair few conversion threads on here if yo want to have a search
    <tuffty/>
    Nov 2013
    Oh **** haha thought it wouldnt be that much, I have ko3s apparently on my car that the guy got before and got it fitted before me but i cant find one anywhereeeeeeeeeeee
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Hey aren't officially called a kO3"s", only known by the S within the tuning range, it's just a slightly larger k03 in Borg Warner's info.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    Rebuild or hybrid the K03s if you don't want to go down the route of a k04
    <Jay A3 build thread>
    241bhp K03s - R Tech
    Nov 2013
    I dont know how much this would all cost, How much would it cost to get it done, i.e would have to get a mechanic to fit it properly and obvs new turbo, What best turbo to get, So i just have a ko3? not a ko3s? lol im confused, not a car mechanic
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Check for boost leaks before you go condemning the turbo.
    If you want to know what turbo you have, look at the ID plate on the compressor housing and see what the part number says it is. Its a small blue tag, and the part number will be something like 5303 123 0053
    TD5 Land Rover Defender build
  1. BHP torque whats the max you can get out of ko4 turbo
    By S3 GEORGE in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2009, 21:39
  2. KKK Ko4 Turbo
    By ALPINE in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th June 2008, 23:43
  3. ko4 turbo rebuild
    By Haglos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2008, 17:06
  4. ko4 turbo ?
    By Daveiow in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th November 2006, 07:29
  5. KO4 Turbo on 98 A4
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2006, 23:00
