Sky InsuranceVolks Autos
Results 1 to 11 of 11
Like Tree3Likes
  • 2 Post By newbster
  • 1 Post By <tuffty/>
Thread: mmm, what's this, and why is it on my table?
    Oct 2013
    in the middle
    90
    well, not the battery
    this is actually good news for my little project
    any materials engineers want to comment on the failure mode of the rivet?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Gearbox selector..
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    yeah shift fork
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Oct 2013
    in the middle
    90
    yep, too easy
    maybe we should call it a 0 - 0 selector fork, because thats what its doing at the moment
    anybody intersted in pictures of a strip down of an 02m gearbox?, its my winter project
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    I have my old 02m box here stuck in 3rd which is where its fork broke several years ago
    did your rivet just shear off?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    Quote Originally Posted by newbster View Post
    yep, too easy
    yeah write it up, would like to see whats involved and how DIYable it is. What are you going to do with it? Just fix the selector fork or are you going to renew synchro/baulk rings & bearings?
    The SQS 02M dog kit comes with strengthened shift forks FYI
    SQS Racing | VW 6sp DOG-KIT 02M
    http://www.sqsracing.com/files/fs_fi...g-boost_92.pdf
    I remember asking them how much it was just for the shift fork modifications but i couldn't justify paying the price at the time my fork rivets sheared
    Alex S3 AMK
    Oct 2013
    in the middle
    90
    my box is noisy as f**k when hot, but its a weird noise, i suspect synchro's, it only does it when rolling fwd in neutral, like down a small incline, clutch in, still noisy, push the stick towards any gear, it goes away, been doing it since i bought the car (2 yeras) so its not terminal (yet)
    the oil was not twilight stylee (sparkly) or dirty, so i ruled out bearings machinging the casing.
    as a fun project i bought one of the many 1st/2nd gear fail to select boxes off ebay
    its a bit of a punt but so far look good
    oil is clear,
    input shaft and diff are good and solid, still plenty of preload
    pulled the shift tower over the w/e, found a nice clean break on the rivit and the selector sitting in the bottom of the box
    a couple of slight bruises where it had contacted a gear wheel, but clearly had not been digested by the gears
    the gears i can see look good.
    i will have a good look when i split the box.
    i hope to do something regarding measuring preload that should help others ,and also on getting the box out
    most guides are a bit blue peter ish, - undo all the bolts and heres one we did ealier!
    i can see what bolts to undo, its the actual moving the box around that missing.
    i have a trolley jack and will make up an adapter in wood to balance the box on the jack
    i was thinking about making an engine beam, but have seen a pretty good one on fleabay for about 50
    anywasy install will not happen till the spring.
    smf???
    s3dave and Alex C like this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Later type 02M box but essentially same principles...
    How to: 02M/02Q LSD Install - TDIClub Forums
    <tuffty/>
    Alex C likes this.
    Oct 2013
    in the middle
    90
    cheers tufty
    i have that link, i also have found a link to a workshop manual for the 02M
    I often forget how awesome the intrewebs is,
    when i was young ( think real mini's) finding this kind of info just was not an option.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Gearbox stuff is thin on the ground tbh... bit of a black art too it seems...
    Need to strip my box and replace the the diff bearings plus do the selector fork mods... I also have a crunchy 1st > 2nd change which is syncro/baulk rings... expensive if the syncro unit is fecked but I am looking at getting a low mileage 02M and swapping internals over... 'easy enough' to do in principle but there are differing ratios to consider... doing a little research at the moment to see whats what
    <tuffty/>
    Oct 2013
    in the middle
    90
    after looking at the fork for a while, i have a theory about why these are breaking, the clue is in the witness marks on the first photo
    and its not good news, i had assumed it was driver abuse, too many "fast & furous" style changes
    but the reported failures are from everywhere, not just the hooliogans
    need to strip out teh the shift tower again
    should take 2 minutes this time
  1. What colour and why?
    By TrisLC in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2013, 12:29
  2. whats this do and why..............
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2011, 12:01
  3. What is this, and why is it making a noise?! (pic)
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2010, 00:05
  4. whats this and is it supposed to be like this?
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2010, 14:57
  5. Not sure what chassis, and why so cheap?
    By denzelburner in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th October 2007, 20:41
